Subject: Re: Is Grass hinge hole pattern compatible with Blum
11/27/16
Matt Calnen
I've been shopping again. Found a great deal on a Grass Eco press. I was wondering if it's drill pattern is compatible with Blum hinges. Thanks.
11/28/16       #2: Is Grass hinge hole pattern compati ...
Dan
A Grass Ecopress will most likely have the older Grass 42mm hole pattern which is not compatible with the Blum or Salice 45mm pattern. New Grass Tiomos hinges are made with the same pattern as the Blum and Salice hinges. Of course you could use the Ecopress to just bore the 35mm cup hole and buy screw-in versions of the hinges.
11/28/16       #3: Is Grass hinge hole pattern compati ...
Matt Calnen
This looks to be a newer machine. I would be having it shipped to me. How should I tell the owner to measure it so I know it's compatible? Thanks.
11/28/16       #4: Is Grass hinge hole pattern compati ...
This is how the boring pattern is measured. The current owner probably knows the answer to your question but, if not, the surest way to check would be to drill a set of holes and measure them or...drill the holes and hold a Salice or Blum hinge up to them to see if they match.
View higher quality, full size image (684 X 476)
