Subject: Re: How to check saw head calibration of Vertical Panel Saw
7/29/17
Nathan Barnard  Member
Website: http://www.nathanscustomcabinets.com
In a recent post I had to troubleshoot problems with my VPS which caused panels to be cut with out of square cuts, causing lots of burning and issues with edgebanding not getting evenly applied to cuts. The process to verify alignment of saw blade alignment to panel in both vertical and horizontal directions is quite easy. Following that you should check the healing of blade following instructions in video link below.
First, remove the saw blade and pressure shoe, then reinstall blade (don't run saw in this unsafe configuration). Install a flat panel on grid and make sure it is touching grid. Lower saw to part shelf and use framing square as in picture to verify blade is perpendicular to panel.
Second, flip motor down into the ripping position and raise above panel. Using framing square once again verify blade is perpendicular to panel in this configuration. Rotate blade several degrees to account for a bent blade.
Thirdly, verify the plunge guide is perpendicular to panel (mine wasn't and I had to add shims behind it under one of the bolts).
I should note that if one of the first two tests showed arbor out of calibration the adjustments are made on the cams for bearings on saw carriage, and they are tricky to set and balance in both directions. Might be time to call a tech to adjust.
Fourthly, check shoe in/out of cutter head to verify saw cutting parallel to beam/movement. This should be repeated in both rip and crosscut configuration. See video linked below by Colonial Saw (it also shows how to remove pressure shoe from Striebig saw, necessary to perform first tests).
Another test once the above is satisfactory is to climb cut only 1/8" deep then take a full depth pass in normal direction. Check cut, there should be no ridge from the shallow climb cut.
Cheers,
Nathan
P.S. After cutting my first half lift I can tell you cutting on a VPS is much nicer than a tablesaw that I have cut thousands of sheets on! Easy on the back, fast and accurate.
View higher quality, full size image (1070 X 1600)
View higher quality, full size image (1600 X 1066)
View higher quality, full size image (1600 X 1065)
Striebig Service Video Compact Parallel
7/29/17       #2: How to check saw head calibration o ...
Additional pics
View higher quality, full size image (1065 X 1600)
View higher quality, full size image (1600 X 1278)
7/31/17       #3: How to check saw head calibration o ...
First thought, man that's one rusty framing square! I know it doesn't make a difference for square, but just saying I don't expect to see machine calibration tools that look like that! LOL
7/31/17       #4: How to check saw head calibration o ...
haha, yeah my nice aluminum one is in the cabinet trailer. Thanks again for that video link Rich.
8/1/17       #5: How to check saw head calibration o ...
I've owned one of these for 15 years. Never leaves the shop. It came as square as a Starrett combo square.
Framing square are not known for being that accurate. I wouldn't use a typical one for setting up a machine.
Stainless Framing Square
