Subject: Re: Pre-mil cutter inserts for Brandt Ambition edgebander?
7/31/17
Matt M
It's time to have a spare set of pre-mil cutter inserts on hand for our bander.
This machine has two cutterheads, 16 inserts total.
I can get them from the vendor we bought it from (Stiles), but before we spend $800 on them, wanted to ask you all what other options are out there, and if there's anyone you recommend for these.
Thanks,
Matt
7/31/17       #2: Pre-mil cutter inserts for Brandt A ...
Rich  Member
We run diamond heads on our pre-mills. Run bander 8 hrs + day and change them maybe once a year. We purchased ours from Leuco. Also put in for rough and fine trim stations and they last even longer, cuts down on tool changes and adjusments.
8/1/17       #3: Pre-mil cutter inserts for Brandt A ...
Matt M
Yeah we got about a year out of these, and we rotated them to expose less-used cutting edges where it mattered.
I will look up Leuco, thanks for the suggestion.
8/1/17       #4: Pre-mil cutter inserts for Brandt A ...
Is it a standard size insert? I would contact a tool maker, like Great Lakes tools before I bought them from Stiles.
8/1/17       #5: Pre-mil cutter inserts for Brandt A ...
Gary Balcom
It's likely either a Leuco head or a Leitz head...Just buy the inserts directly from them.
