Subject: Re: Shaker doors with mdf panels
10/31/17
Todd Miltier Member
Can someone recommend a door manufacturer that uses a mdf panel in their shaker doors? I am having a problem with my current supplier. They use glued up panels and I am getting a concave line at all glue joints.
View higher quality, full size image (2448 X 2448)
10/31/17       #2: Shaker doors with mdf panels ...
cabmaker
My guess is that concave line comes from them wide belt sanding the panel before the moisture from the glue has left the panel.
The moisture swells the lumber right at the joint. If they wide belt it before the moisture has had a chance to migrate out the lumber will be still be swollen when it is passing through the sander. Eventually the moisture will dissipate and the lumber will shrink left & right of the glue joint.
I learned that here on the wood web with some solid lumber drawer faces we were building. We did some tests and the problem was clearly owing to moisture from glue up.
10/31/17       #3: Shaker doors with mdf panels ...
Todd Miltier Member
That's what I figured it was. I need to order doors within the next week and can't afford this problem again.
I am having a hard time finding a supplier that uses plywood or mdf panel.
10/31/17       #4: Shaker doors with mdf panels ...
Mark V.
Conestoga
11/1/17       #5: Shaker doors with mdf panels ...
Ed
Patton Cabinet doors, they use a 3/8 mdf panel. 512 918 3737
Had that same problem on some thick maple glue ups , have to let it sit a long time before going to wide belt.
Ed
11/1/17       #6: Shaker doors with mdf panels ...
Hen Bob Member
Walzcraft
11/1/17       #7: Shaker doors with mdf panels ...
Pat
Meridian.
11/1/17       #8: Shaker doors with mdf panels ...
Leo G
In order for that problem to not occur, the panels need to sit for about 3 days. No production company will be doing that.
When I make doors the panels sit while I do other things for the kitchen. It probably takes a week before I get back to them and they get the final sanding which takes care of any dips.
Like you want, MDF for paint grade is a much better choice for reasons other than no glue line showing up. More stable and paints easy, no grain to fill.
11/1/17       #9: Shaker doors with mdf panels ...
Tony
Kendor Woods, Mayfield, Ky
11/1/17       #10: Shaker doors with mdf panels ...
Todd Miltier Member
Thanks for the replys. New doors have been ordered.
11/14/17       #11: Shaker doors with mdf panels ...
Harold morantz
Website: http://morantzcustom.com
Try an all mdf one piece shaker, 7.50sqft, paints great and no cracks, havevleft in buckets of water with no swelling , no brainer
View higher quality, full size image (1938 X 1938)
View higher quality, full size image (1487 X 1000)
