Subject: Re: Castle Tsm 20 pocket machine issues
5/24/19
Ray
Does anyone have a router retrofit for this machine ? My 3102hd porter cable router (the small one) quit working and there are no new ones to be had. I contacted Castle and they said too bad and the tsm 21 has obsolete motors as well with no retrofit.
They said my only choice was to buy a tsm 22. My local machinery repair shop said they only had brushes and bearings.
probably cost a small fortune to have it rewound if they can do it.
5/24/19       #2: Castle Tsm 20 pocket machine issues ...
Dustin orth
Find a machine shop that can bore out the body of the dead router, find a Makita or rigid and use that inside the dead one. I have that setup in one of my castle machines. I think someone has this in the shop built category as well.
5/25/19       #3: Castle Tsm 20 pocket machine issues ...
MIKE
send a few pics of router & the way it is mounted. you should get lots of advice doing that.
no such thing as can't do in today's world.
5/25/19       #4: Castle Tsm 20 pocket machine issues ...
Last year I dumped both of my older castle machines on Craigslist and bought two new ones. I thought it was the easiest path.
New ones are easier to change bits. I think the routers are better as well. The case and top aren't as nicely made though.
5/27/19       #5: Castle Tsm 20 pocket machine issues ...
Ray
I fixed the castle tsm 20 by using a Makita 1.25 hp router which is 128 thousands smaller then the clamping device in the front and 260 thousands smaller then the back support. I made a couple of spacer rings out of 1/2 inch uhmw plastic cut on my cnc router. using artcam software, they slide perfectly over Makita with a nice snug fit. Now I don't have to find an obsolete router. it's a shame that castle hasn't helped out by providing this simple solution. I get that they want you to buy a new one but this sure has left a bad impression on me for future sales . it's my understanding the tsm21 has the same problem with obsolete routers. it wont be long and the 22 will be in the same boat. I hope this helps out others. Thanks for the reply's everyone.
5/27/19       #6: Castle Tsm 20 pocket machine issues ...
MIKE
very good Ray & with pics. as i said earlier there is no such thing as can't.
5/27/19       #7: Castle Tsm 20 pocket machine issues ...
Ray
Thanks Mike, I sent an email off to castle with a link to this page, maybe they will respond and do something about it so others are stuck dropping 4k on a new machine.
8/12/19       #8: Castle Tsm 20 pocket machine issues ...
Mark
eBay or Craigslist.
New, old stock or lightly used ones show up all the time and PC also made routers for DeWalt, that with slight modification will work (change the top cover). I have multiples so I am good till I sell the machine.
Mark
8/12/19       #9: Castle Tsm 20 pocket machine issues ...
Mark
All but one of these were purchased after learning they were discontinued. One was purchased right after I got the machine to have a spare on hand, just in case. And yes, I use them for other stuff too.
Mark
8/12/19       #10: Castle Tsm 20 pocket machine issues ...
Mark
Oops,
I just realized that I have the TSM-21 and these are the 7301 routers, which are also discontinued, so hopefully this will help others too...
Mark
