Subject: Re: 5 piece doors minus a stile.
2/28/22
David Wildman
Website: http://www.durhamfab.com
Hi
I have seen on the interwebs and am now being asked to build some 5 piece cabinet doors that are missing a stile (now 4 piece doors) so that when paired, look as if the two doors are actually one. I am trying to find a picture to add but can't. Basically the left door has no right stile, and the right door has no left stile. Is this as simple as making the 3 remaining pieces of the frame (2 rails and 1 stile) and gluing the panel in (and maybe ripping to clean up the edge)? Or is it more complex? I am a little leery of this, but have seen this done. Beyond adding a domino to the remaining cope/stick joints not sure what else to do. These are flat panel doors (so 1/4" veneered ply/mdf). White oak so can't make them out of mdf. Thanks.
2/28/22       #2: 5 piece doors minus a stile. ...
Mark B
Typical rail/stile construction. Pin the panel at the door gap so it stays consistent. All your panel movement is towards the L/R stiles. Think bread board edge. Let the entire panel float other than gluing/pinning/doweling the door gap edge to keep it fixed.
Works flawlessly. Of course your material has to be stable and well prepared.
3/1/22       #3: 5 piece doors minus a stile. ...
Mark  Member
+1 with what Mark said
Use this method with bifold cabinet doors also
Have a pic but couldn't get it to post, sorry
3/1/22       #4: 5 piece doors minus a stile. ...
Adam Spees
You can glue the panel into the stile/rails. That is our standard construction method with mdf/ply panels. It makes better doors. No rattling, no paint cracking, no space balls.
3/1/22       #5: 5 piece doors minus a stile. ...
David Wildman
Thanks all. One more question. For the mdf/ply panel (1/4" thick) that is going to have the edge exposed, do you do anything to it to dress that edge up (edgband?) or leave it as exposed?
6/28/22       #6: 5 piece doors minus a stile. ...
Mike Sorensen
Typically we'll build these as a single 5 piece door with added 1/8" to overall width, cut it in half and pin nail the panel to the rails either side. Gets the advantages of grain matching in stain grades, and follows our standard processes better.
We use space balls for panels, and tend to putty/bondo the gap between panel and rail on the end so they don't see that, but otherwise leave it as is.
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
