Subject: Re: Widebelt conveyor belt cleaning
9/1/22
Jim
I recently added a dual orbit widebelt (12inch x 43inch platen with brush on second head)
I'm having trouble with the rubber conveyor belt transferring a black smudge from the belt to the finished door.
The belt has 900hrs on it and looks and feels basically new and has zero slippage of parts.
I've sanded the belt surface with a 5 inch Dynabrade sander and washed the surface with lacquer thinner, but still getting some smudging.
Anyone know a remedy for getting rid of this transfer?
Picture attached
1st is on conveyor belt
2nd is face to orbital platen
3rd-sander
9/1/22       #2: Widebelt conveyor belt cleaning ...
I would never wash rubber with lacquer thinner. It will break down the rubber and cut the life of it dramatically. Simple green is my favorite cleaner. You might try dusting it with fine sawdust or talcum powder to see if that soaks up something. I've never seen that on a feed belt. How old is the machine?
9/1/22       #3: Widebelt conveyor belt cleaning ...
Jim
I don't know the exact age of the machine
Clock reads 908 hrs and the internals, wiring, and conveyor belt are near new looking.
The belt is pristine and grippy.
Doesn't transfer to cloth or hands, but when the door comes out there is black on the door that mirrors the feed belt.
There's no black dust and the belt surface appears fresh.
Baffled in Texas.
Guess I'll try some talcum powder and see what happens
Thanks for your input
9/1/22       #4: Widebelt conveyor belt cleaning ...
Makes me wonder if the previous owner used some kind of automotive tire cleaner or treatment. Then I would worry about silicon contamination. Run a scrap through it and then spray it. See if the clear lays down okay.
9/1/22       #5: Widebelt conveyor belt cleaning ...
Jim
Machine hadn't been cleaned/prepped at all, and had been in storage
Purchased from a planing mill that purchased it along with a molder.
Will say it does a great job removing cross grain scratches after coming out of a two head SCMI
Now if I can address the black transfer from the conveyor belt
Will see about washing the belt with simple green next
9/6/22       #6: Widebelt conveyor belt cleaning ...
M Member
Everything I have read is to use isopropyl alcohol
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
