Subject: Re: Floating shelves
Floating shelves
3/24/23
Payne Chris
What is the best product out there for floating shelves. I heard someone talking the other day about one that had an easy leveling device on it but I can’t find anything on it. I would appreciate your help.
3/24/23       #2: Floating shelves ...
Floating Shelf Bracket
3/25/23       #3: Floating shelves ...
Payne Chris
Leo
I have been looking at this type have you used them before?
3/25/23       #4: Floating shelves ...
I've used it a couple of times. You have to buy the drill bit to make it work. If you are just doing a few shelves you can use the guide they give you with each kit. But if you plan on making a lot of shelves by the drilling guide that is for the bracket you are using since it's already spaced out properly.
3/25/23       #5: Floating shelves ...
Payne Chris
Thanks Leo that’s real helpful I will check into getting me one.
3/25/23       #6: Floating shelves ...
james e mcgrew  Member
Light shelves can ve done with surface metal brackets or wood cleats. we do a lot where they are heavy (Stone) or in commercial applications where we use an angle inwall bracket preattached to studs before sheetrock or surface is applied
View higher quality, full size image (981 X 826)
View higher quality, full size image (1259 X 796)
3/25/23       #7: Floating shelves ...
pat gilbert
I just use lag bolts and then cut the heads off then drill holes in the shelf
3/25/23       #8: Floating shelves ...
Payne Chris
Where can these black metal brackets be bought? Those Sheppard brackets look like the way to go.
3/25/23       #9: Floating shelves ...
Sheppard Brackets
5/27/23       #10: Floating shelves ...
Dave Skinner
Website: http://WeDoClosets.ca
This is a nice system that I have used. called Hovr
https://hovrsolutions.com/
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
