Subject: Re: Blum mini press
Blum mini press
1/15/26
Earl Anderson Member
My Blum mini press is burning when boring even with a new bit. Anyone had this issue?
1/15/26       #2: Blum mini press ...
Plunge speed too slow?
Correct direction tool?
Did it get whacked with something and isn't traveling vertically?
I'm just spitballing
1/15/26       #3: Blum mini press ...
I have adjusted the air pressure as far as it will go within the limits required. It just doesn’t seem to want cut and just burns the wood. New bit. It travels up and down just fine. I haven’t got a clue.
1/15/26       #4: Blum mini press ...
I did notice that there is some play in the main shaft.
1/18/26       #6: Blum mini press ...
New bit doesn't necessarily mean it's sharp. It should be. But it could be incorrect.
1/19/26       #7: Blum mini press ...
cris
The cup drill is right hand the screw drills are 1 right hand 1 left hand, check that they are correct
1/19/26       #8: Blum mini press ...
Nate k
Couple things. Make sure bit is proper rotation, and in the correct location, the most central. Bit should probably be black, the others are orange, reverse rotation or vise versa Does it plunge all the way in setup mode? Is the plastic depth stop engaged? Did it work before or new to you?
1/19/26       #9: Blum mini press ...
is it 3 phase and wired backwards?
1/20/26       #10: Blum mini press ...
Alex_Zhang Member
I'm with Cris on this one.
'New bit + Burning immediately' is the classic symptom of a Wrong Rotation (LH vs RH) bit.
It happens all the time because Left-Hand bits (often used on line borers) look identical to the Right-Hand bits needed for the main Mini Press spindle. If you put a Left-Hand bit in a Right-Hand spindle, the cutting edge is trailing, so it acts like a friction welder instead of a cutter.
Quick check: With the machine OFF, look at the tip of the bit. Imagine it spinning. Is the sharp edge leading the cut, or is the rounded 'heel' hitting the wood first? If it's the heel, that's your problem.
1/26/26       #11: Blum mini press ...
Daniel French Member
If it’s burning instantly with a “new” bit, I’d still bet on rotation or runout. A left-hand bit in a right-hand spindle will just rub and cook the wood. Also, that play in the main shaft is a red flag—worn bearings will cause chatter and heat fast. I’d verify bit hand, spindle direction, then check bearings before chasing air pressure.
2/12/26       #12: Blum mini press ...
Wally Robinett
Burning right away with a “new” bit almost always screams rotation to me. I’ve seen left-hand bits get swapped in by mistake and they’ll just polish the hole instead of cutting. That little play in the shaft wouldn’t help either — any runout will build heat fast. I’d confirm bit hand and spindle direction first, then look at bearings.
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
