Subject: Re: Salice drawer slide problems
2/2/26
al
I’ve been using Salice F70’s for quite awhile now. I like the slides but have some issues with latest ones I received. I generally by from Hafele and now and then I get a bad slide and they do replace them. I have one slide where one of the little white wheels is off at front, there is supposed to be two. The wheel was in box. The pin that holds wheel is missing.
The more serious issue is that some slides come out about half way and get stuck and quite a few are not coming out fully. I have posted a couple pictures. The slide on left is fully out while right slide is about 1” behind the left. I have been ordering full cases. These are 18” slides packed 6 lefts in one box and 6 rights in a separate box. They arrived un damaged and my shop never below 65 so it is not a cold issue. Anyone else having these problems with the F70’s?
Thanks , Al
2/3/26       #2: Salice drawer slide problems ...
al
So I corrected the issue but not something I want to do every time I order slides. I removed black plastic gear rack off of slide. There are 4 screws that mount track to slide. Pull slide to fully open position then reattach black track to slide while open. They open fully now.
Salice needs to address this problem asap.
3/13/26       #3: Salice drawer slide problems ...
Daniel French Member
Drawer slide issues often come down to alignment or installation tolerances. I’ve run into cases where even a small twist in the cabinet or uneven spacing between the slides caused sticking or poor movement. Checking that both sides are perfectly level and that the drawer box dimensions match the slide requirements usually helps solve it.
3/13/26       #4: Salice drawer slide problems ...
al
That was not the problem. Right out of the box the slides did not open fully.
3/27/26       #5: Salice drawer slide problems ...
David William  Member
If multiple slides in the same batch aren’t extending fully, it could be a manufacturing defect or mismatch between left/right tolerances. The missing wheel pin definitely points to QC issues. Before installing, I’d test each slide individually and lightly lubricate to rule out binding. Also double-check cabinet squareness, minor misalignment can cause uneven extension. Since you’re buying full cases, it might be worth trying a different batch or even switching suppliers temporarily to see if the issue persists.
3/30/26       #6: Salice drawer slide problems ...
al
I just received more Salice F70’s. Same problem as before with most of them. If using these check and make sure slides are opening fully. They don’t need to be installed to notice problem just try before you mount them. The hook that fits into back of drawer hole should slide out to first mounting hole of slide front. I suspect guys have been using these slides and not realizing the drawer is not opening fully.
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
