Finishing with a Flatline
11/4/15
Dave Member
Website: http://www.north52cabinets.ca
Good day, Im running a Chefla Flatline and only on darker colours with any kind of reds I cant get away from the "halo" but its only on shaker doors, any ideas? We use a 50/50 diluted stain pen to run along the inside but its not working. Any info would be great!
11/10/15       #2: Finishing with a Flatline ...
Kevin
lower atomization air, increase spray gun angles, and slow down (retard) the stain with a slower solvent (think mak or in some cases water works well if using dye stain with acetone). also, having your spray guns in a diamond pattern will help this. I assume you are using low pressure guns.
