Festool edgebander
3/31/17
alain  Member
Website: http://www.bisarowoodworking.com
I'm just a 1 man shop doing half custom furniture half cabinetry , always struggled with the edgebanding part ,,,
wondering if this Festool bander is worth looking into ? I'm limited by space and cash flow !! better options ?
cheers
3/31/17       #2: Festool edgebander ...
Limited cash flow and Festool does not frank
4/1/17       #3: Festool edgebander ...
Steve G Member
Website: http://www.cullengrace.com
Look into the Fastcap system this may work for what you are looking for.
Fastcap System
4/2/17       #4: Festool edgebander ...
GSXON
seeing a lot of these sarcastic reply's to posters recently.
someone once said if you have nothing constructive to say then say nothing.
just because you have a mouth or can spell doesn't mean we all need to hear the vacuum in your head
there is a big difference in 5Gs for a hand held and 20Gs for a stationary machine
does that compute
4/2/17       #5: Festool edgebander ...
alain  Member
Well where I'm at is either a used small hot glue edgebander or maybe this Festool setup ... I would like to hear from people using it .
a 20k machine is just not in the cards at the moment
4/2/17       #6: Festool edgebander ...
GSXON
I would think that a low end stationary would be disappointing
Festool make good tools, with the manual edgebander you still have trimming to do, but a good set up with a router table will fix that, and the flexibility of doing curved work exceeds most stationary machines
my 2 cents
4/3/17       #7: Festool edgebander ...
Roy
Hi Alain. I have the Minimax ME20. It was $12500 cad. i have been very happy with it. it is the small gluepot bander able to do up to 2mm in coil or 5mm in strips. The small Felder machines look nice as well.
4/5/17       #8: Festool edgebander ...
Derrek
I have the Festool portable contour edgebander. This thing is very high quality, does and excellent job applying tape, is easy to use and has several great features. I really like that it tells you how many feet of tape can be applied with the available glue. We do only contoure parts with it and have a large Biesse machine for our straight line items. I prviously had another brand small glue pot contour bander that I hated from day one.
Yes it is a little pricy at about $3500, but it is ten times better machine than the one I paid $2500 for. I would take this over any of the lower end "hot air" machiines.
