Door Bumpers
5/18/17
Stewart Member
Does anyone have a good solution for door bumpers? I use the adhesive backed clear and felt bumpers and I swear if I go back to the job site, even within just a few months, several will be missing and others will have a "slime" trail where they have walked from the original position. No one has griped about it but It's driving me crazy...
5/18/17       #2: Door Bumpers ...
Jeff Mills
We switched to the 3M branded ones from Richelieu and they seem to stay one. Cheaper ones we were using constantly falling off.
5/19/17       #3: Door Bumpers ...
harold Morantz
soft close hinges=no more bumpers. or leave some with the client.
5/19/17       #4: Door Bumpers ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
Use stem bumpers, you drill a hole for
them to be inserted into.
Stem Bumpers
5/19/17       #5: Door Bumpers ...
Jim Clark  Member
If that link doesn't work look on Ebay
under "cabinet stem bumpers"
5/23/17       #6: Door Bumpers ...
Mike Fuson
I'm with Harold, since we do soft close on everything now we don't see a need for them.
5/24/17       #7: Door Bumpers ...
Josh Koschak Member
Without bumpers, how do you get the door to sit parallel with the face frame?
The door does not slam with soft close hinges but concealed euro hinges hold the hinge stile away from the face frame.
5/24/17       #8: Door Bumpers ...
Gerry
Before soft close we used the drill in style to prevent the bumpers from moving or falling off. Now we use adhesive just for a shim as Josh states to keep doors and drawer faces parallel. I find with the soft close the bumpers stay on better and don't move as much. I think drill in is the premium option but it is a lot more work.
5/24/17       #9: Door Bumpers ...
Harold morantz
We do not make faceframe cabinets and use 37mm set back for system holes. The doors have no gap on the hinge side and drawer faces are flush as well,
5/24/17       #10: Door Bumpers ...
Mike Fuson
If I were still using compact hinges then I would use bumpers because the hinges would create a big gap but the two piece hinges aren't that bad.
