Case clamping upper cabinets
5/31/17
Chad Member
I'm new to the case clamping world. I just got a Uhling HP 3000 M. I am wanting to know what is involved with clamping upper cabinets since I only have a front and back beam for bases and nothing in the middle for the uppers. Just an empty hole. Any suggestions?
5/31/17       #2: Case clamping upper cabinets ...
I'm not understanding your question.
I looked at that clamp on line. It is a simple very basic clamp with only horizontal clamping. It really shouldn't matter whether you are clamping base or uppers. The top & bottom of the case is between the sides for both. Are you trying to have the uppers have the bottoms hanging from the sides? Not a real good idea, structurally! Higher end clamps have pressure both horizontally and vertically so they automatically square the case. The back is then fastened to maintain square while still in the clamp.
I've never used a Uhling. We've got a Ganomatt Concept Primus 90. It doesn't require any changes between case types or sizes or how many stretchers there are. Push green button!
5/31/17       #3: Case clamping upper cabinets ...
Chad Member
My uppers are only 12" deep and the opening in the middle is 17" wide. The uppers will drop in the opening.
5/31/17       #4: Case clamping upper cabinets ...
cabinetmaker
through a piece of plywood with two keeper strips on it to not slip that will keep it from falling into the "canyon"
6/1/17       #5: Case clamping upper cabinets ...
Strange design. So do a little redesign on your own.
6/1/17       #6: Case clamping upper cabinets ...
Alan F.
Chad you don't have the bars that run horizontal?
View larger image
6/1/17       #7: Case clamping upper cabinets ...
Alan F.
Chad,
Ours is blocked up to align with the conveyor
A-
View higher quality, full size image (2117 X 2823)
6/1/17       #8: Case clamping upper cabinets ...
Chad Member
Alan,
Yes, I do have the bars across the bottom. The problem is that the bars are great for base cabinets but for the upper cabinets the horizontal bars are spread out to far and the cabinet falls in between the bars.
I guess all I need to do is put a couple of 8" pieces of ply from front to back for the uppers to sit on.
