Building Frameless Closet
1/11/18
Ryan
We have a frameless closet job coming up. We are very new into the frameless world of cabinets. We do have a nice edgebander so that part isn't an issue. The one main question that I have is what kind of connectors do most people use to assemble their closets. When you look at closets made my closet companies it seems like everything is put together with connectors. At this point we do not have a CNC. Everything will be done on a sliding table saw and a double row line bore machine.
1/12/18       #2: Building Frameless Closet ...
Derrek
Website: http://Www.closetdr.com
Closets are not built like cabinets. In a cabinet, each box is a self contained unit with top, bottom, back and sides and are assembled in the shop. Closets usually have no back and use a common partition that shelves connect to and are assembled at installation. There are a couple options on connectors, we use a couple different Rafix fittings from hafele. You can drill for these fittings with a hinge boring machine with different bits in it.
