Scissor lift table
10/7/18
Eddie
Hello
Looking to upgrade 2 of my working benches to lift tables, few options out there, any recommendations of Brand or where to get from the ones who have lift tables? thanks
10/7/18       #2: Scissor lift table ...
Steve Member
Approximate size would be helpful please.
10/7/18       #3: Scissor lift table ...
Eddie
I will built a wood top for it, If the lift comes with a 24'' x 36'' top will be fine.
10/7/18       #4: Scissor lift table ...
The best one is the one you get at auction.
10/7/18       #5: Scissor lift table ...
Steve Member
Although I am not using one I have been following them for awhile. I started a suggestion but then realized your OP as sparse as it is, needs you to give some idea of need/use, then Google just one or two and you will be flooded with possibilities. elec, pneumatic; load size... then I think you will get some answers here. good luck.
10/8/18       #6: Scissor lift table ...
Eddie
I'm not settle yet with elec. or pneumatic, load size etc.... that's why I asked "Any recommendation from the ones who have lift tables". This is a cabinetmaking forum, I am gonna be using for cabinet assembling!!
10/8/18       #7: Scissor lift table ...
Paul Miller
We have both and I bought both at on line auctions. I paid about $1,500. The electric lift we use for assembly and general woodworking. The pneumatic we use to stack our panels on next to our CNC. As you pull a sheet off, the pneumatic, the lift raises the load up so that the sheets are still at the desired height. It is more difficult to adjust the height on the pneumatic. Good investment.
10/8/18       #8: Scissor lift table ...
Hen Bob Member
We have a few. All Southworth ones, some we bought new some at auctions. We have a rolling cart style one 32 x48 that we use for assembly. Worth every penny.
10/9/18       #9: Scissor lift table ...
Jonathan Bryant Member
Autoquip.com
This is an Oklahoma manufacturing company that specializes in lift tables. Certainly an investment but one that will last.
Hope this helps.
https://autoquip.com/product-categories/scissor-lift-tables/
10/9/18       #10: Scissor lift table ...
Eddie
Thanks for the Help guys, definitely will get 2 of those lifts together. Thanks again
10/14/18       #11: Scissor lift table ...
David Vant Voort
Dont mean to turn this into a garage forum by bring Harbor Freight into it...but
we have a large 5'x10' Southworth electric-hydraulic scissor lift as our main assembly, cant beat it besides price...Has the mass and weight to fight back when sanding and can lift 2k lbs.
When we moved to a bigger space I wanted more lift tables for cab assembly but didn't want to spend the coin. Instead I bought two Harbor Freight motorcycle lifts and put 4x8 tops on them. It takes a foot pumping action to raise and lower them, and not a lot of mass, besides that they work great. They go on sale for 299.99 a piece, plus 20% off.
10/17/18       #12: Scissor lift table ...
Larry Schweitzer
We've got a 5,000# lift at the beam saw, 2 - 2500# lifts bought new, in assembly and 2 - 1500# lifts that I bought used also for assembly. All are electric/hydraulic. All have been in constant use for years and no problems. So much nicer to work at just the right height! I installed steel I beams on the assembly benches so we could put a 10' melamine top on them w/o sag. All have the foot pedal control. Worth their price even if you have to buy new.
10/26/18       #13: Scissor lift table ...
Madera
Check out the Felder FAT 300XL or 500. Or Barth makes a few differen models. The best price for a great quality table is a German company called R.E Beck
