Holzher 1435 se Genisis edge bander issues
12/27/18
Mike nacke  Member
I recently bought a used holzher edgebander that was supposed to be in working order but im having issues. After the machine warms up and you press the button that starts all of the trimmer motors it will shut the machine down or it will light up only while its pressed in. If you hold the main power button (the one that initiates warm up cycle)and that button down together it will rapidly cycle off and on rapidly but will eventually start up after 5 or 6 seconds and run beautifully for a few minutes than it kicks a breaker inside the machine. I don't think its a big problem just could be so many different things i don't know where to start. I was hoping that somebody that has this model or similar may have possibly had this issue before and could help get me in the proper direction.
Any help is very much appreciated!
12/29/18       #2: Holzher 1435 se Genisis edge bander ...
cabinetmaker
open all the access panels make sure the electricity is off and carefully check every connection. every single item
Don't wrench like crazy just make sure is all snug and seated well
If not decommissioned properly and set up for shipment, lots can rattle loose and you could chase your tail like crazy
Also, make sure, if there is a multi tap transformer, you are in range with your electrical power
2/16/19       #3: Holzher 1435 se Genisis edge bander ...
Jay Member
Mike, if it has the high frequency motors call a good tech in and pay for a day with them. Like a Lee Johnson. If it has the older 'standard' frequency motors, just turn it in for scrap metal.
The 1435 still had the old scissor trimmer mechanism. Very fussy to work with and never super precise, but so long as you are not trying to make a finished door or something off of it, it is probably worth a few dollars to get working right.
