Edgebanding prefinished material
5/22/20
Good morning All.
I know it's possible to do almost seamless banding with high gloss materials and tape.
Can that also be done with prefinished veneer and prefinished tape?
If so, what type of equipment is needed?
Thanks.
5/22/20       #2: Edgebanding prefinished material ...
Alan F. Member
Laser edge-banding is what is used on Acrylics, the glue line is part of the banding and is fused to the edge.
Some machines use very hot air, some uses lasers.
REHAU LaserEdgeTM
5/22/20       #3: Edgebanding prefinished material ...
Jared E
Veneer has the finish only on the face. Its thickness, whether .5mm or 1.5mm or whatever, will not have the finish on it since your bander will have trimmed it. No matter how good the glue joint, the banding's thickness will come out unfinished, so I wonder if it would even be worth it to pursue.
5/30/20       #5: Edgebanding prefinished material ...
Rob Young  Member
There are multiple ways to achieve a seamless edge. Some machine manufacturers are pushing laser and hot air. You’ve already identified one of the limitations of those systems. They are limited to co-extruded edgebanding. PUR can produce a seamless joint, provided it’s the right PUR system, with veneer, ABS, PVC, HPL, and solid wood edges. The attached pictures are panels that were run in a production shop in Austria on an Ott edgebander. The patented Combimelt glue system utilizes stepper motor control to precision adjust the glue dosage. The Combimelt glue roller is driven from above. This means no leaking seals in the bottom of the pot to run down the glue roller drive shaft.
Much of what people have heard about PUR and maintaining a PUR glue pot is based on outdated procedures from the mid-90s. The Combimelt pot is easier to maintain than an EVA glue system and doesn't require daily, weekly, or even monthly cleaning. Part of the technical training we received at Ott was glue pot maintenance. We pulled the glue pot and hopper (took about 30 seconds), placed it on the service station, filled the pot with Jowat 930.60 (a reusable cleaning agent), heated the pot, went to lunch, emptied the liquid when we returned, wiped the pot out with a cloth rag and it was ready for use.
Along with the proper glue system you need to present a properly machined edge. A set of diamond premill units is invaluable in achieving this.
View higher quality, full size image (4128 X 3096)
View higher quality, full size image (774 X 1032)
View higher quality, full size image (1002 X 652)
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
