Crate Construction
4/27/21
Matthew Jenkins Member
I crate and ship flat pack furniture nation wide. Volume is fairly low, about $100k annually, so I hadn't spent too much time on optimizing crating up until now. Crates are 87" x 48" with a height of 20". I use 3/4" plywood for the deck and the ends, and 5/16" OSB for the sides and top. But with OSB going through the roof, I'm looking for new materials and construction style. Would appreciate any suggestions.
4/27/21       #2: Crate Construction ...
You don't mention weight capacity, but I suggest you talk to a local cardboard container company. They can build to any spec and weight requirement. If you have to ship on a pallet, then look at used wood pallets.
4/27/21       #3: Crate Construction ...
pat s gilbert
What Rich said
4/27/21       #4: Crate Construction ...
Weight ranges depending on the package from about 400 lbs to about 600 lbs. Could be wrong, but that seems a bit much for cardboard.
I did receive a boring machine awhile back (probably 500 lbs or so) that was sitting on a pallet and had 1/4" plywood all around with some sort of metal corners and no top. That may be an option.
4/27/21       #5: Crate Construction ...
400-600 pound piece of furniture? WOW
4/28/21       #6: Crate Construction ...
pat s gilbert
I used to use double corrugated boxes that withstood a surprising amount of weight items that weighed 100 lb + 18" x 24" x 96"
4/30/21       #7: Crate Construction ...
Puzzleman Member
I ship assembled toy boxes throughout North America. They don't weigh even near 100 lbs but haven't had any problems with UPS with damage.
I take a cardboard box that is double walled, line it with 1/4" mdf or plywood, line that with 1/2" styrofoam sheet. Then the box is placed inside and the styrofoam and mdf are put on top. The box is inside a large plastic bag so the foam doesn't mar the finish.
    • Denray Machine
    • WOODWEB, Inc.
    • Country Saw and Knife
