Door and Frame Shop Recommendations (Northeast)
5/23/22
Drew Z Member
Website: mdaddio.com
Hi all,
I am looking for a door and face frame supplier who offers doors at 7/8" thickness, pre-finished.
The company we have been using for our components will only produce 3/4" or 1" thickness and we would like to have 1" thick frames and 7/8" doors. We set our floors and stretchers inside the face frame to act like a rabbeted door stop and when using cup hinges we need the clearance so the doors open and close without binding.
Struggling thus far to find someone to work with. We are located in the New York City area. We know if necessary we could get unfinished doors and run them through the sander at 7/8" but we'd much prefer to not need that step.
Thanks for your help,
Drew
5/24/22       #2: Door and Frame Shop Recommendations ...
I've never heard of a face frame supplier. Are you asking for parts or completed face frames? Just curious.
5/24/22       #3: Door and Frame Shop Recommendations ...
Drew Z Member
Website: http://www.artifexhome.com
Completed face frames. We use Meridian Products, and I may have found a shop that does what we need, Custom Doorcraft. Both in PA.
6/3/22       #4: Door and Frame Shop Recommendations ...
It's more common to do 3/4" doors with 13/16" face frames.
We used to edge band the bottom of our uppers. Keep them 3/8" proud of the lower face frame and use that as the stop. That was a long long time ago in a galaxy far far away. Before all of the modern slow close euro stops.
The costs of going with 1" frames and 7/8" door will massively increase the costs due to thicker rough wood. Also the economics of using non standard doors. You will also be limited to the hinges you can use.
Personally, I don't see what you are gaining by going to thicker doors. 1/16" is enough to prevent binding. 1/8" is excessive. You use 1/16" when installing door stop on interior doors.
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
