BLUM MINI PRESS
11/13/25
JOHN ALLAN Member
Website: http://arkansawooddoors.com
When cup hole drill bit makes contact with wood the RPM drops to near stall if you were to continue with drill process. Looking for knowledgeable guidance as to the part needed or better yet contact info to discuss options.
11/14/25       #3: BLUM MINI PRESS ...
Slow the descent of the bit or maybe sharpen the bit. If neither of those two solve it, it may be a damaged motor.
11/19/25       #4: BLUM MINI PRESS ...
Mike D  Member
I agree, the decent is too fast in conjunction with a dull bit. Also check your air pressure which is required to push the bit into the wood.
11/28/25       #5: BLUM MINI PRESS ...
JohnBrown13 Member
The Mini Press shouldn’t bog down that much when the bit makes contact. I’d check the drive belt and tension first, then the motor brushes if it’s an older unit. If everything looks good mechanically, it might be worth calling Blum’s tech support — they’re usually pretty helpful with diagnosing power loss issues on the presses.
1/15/26       #6: BLUM MINI PRESS ...
Earl Anderson Member
Was wondering how this issue was solved.
    • Denray Machine
    • WOODWEB, Inc.
    • Country Saw and Knife
