Holz-Her 1435 MF PVC issue
4/12/25
Remus Ghincu
Hello to everyone,
I have problems with a edgebandmachine (it glues a band on the edge of a board) of type Holz-Her 1435 MF PVC.
Sometimes it workes well but sometimes it does not cut the restband at the end of the wooden board.
It does not have a PLC but this part of the electrical diagram is made by 5 contactors, 24VDC.
Does by chance anyone have this kind of an electrical diagram for this machine ?
Any help would be appreciated
Thanks, Remus
11/29/25       #2: Holz-Her 1435 MF PVC issue ...
SaraWil1515 Member
On older Holz-Her machines without a PLC, the end-trim is usually triggered by a simple limit switch or proximity sensor tied into those contactors. If that switch is dirty, loose, or intermittent, the trimmer won’t fire every time. I don’t have the exact 1435 MF diagram, but checking the end-sensing switch and all 24V connections would be my first step — those machines are notorious for flaky contacts.
11/29/25       #3: Holz-Her 1435 MF PVC issue ...
remus
Hello SaraWil1515
Thank you for the response,
i have already solved the problem, cause i am electronics engineer, and it was indeed a limit switch
    • Denray Machine
    • WOODWEB, Inc.
    • Country Saw and Knife
