Computer Aided Design
Subject: Re: Setting V grove bit in Cabinet Vision
9/25/21
Bob Member
I'm trying to setup 50 degree V-Groove DIMAR DC-5R8-50S bit in cabinet vision tool library ( mdf doors)
But somehow still can’t finish corner properly.
I will need help with setting or designing too in library.
Here is link from Dimar website
https://www.dimarcanada.com/products/cnc/v-groove-cutter
View higher quality, full size image (483 X 588)
View higher quality, full size image (483 X 654)
9/25/21       #2: Setting V grove bit in Cabinet Visi ...
Joesph Stahl
Are you sure its drawn accurately? It looks like it thinks its 45 degree
9/25/21       #3: Setting V grove bit in Cabinet Visi ...
Bob Member
Not i'm not sure if i draw accurately
Bit what i want to use is 50 degree
DIMAR DC-5R8-50S
9/27/21       #4: Setting V grove bit in Cabinet Visi ...
Joesph Stahl
In the tool setup under "Cone angle" what number did you put there?
9/28/21       #5: Setting V grove bit in Cabinet Visi ...
Adam B Member
Bob,
As mentioned above, you will need to draw the bit accurately as it is in real life. That is what determines the angle your machine will use to ramp in & out of the corners, leaving you a sharp continuous route pattern. Looks like your bit is drawn @ 45deg which is telling your machine to ramp in & out @ 45 degrees in the corners when in fact the cutter that you are using is 50 deg. Your tooling supplier should have a pdf or spec drawing of some sort for you to follow
9/28/21       #6: Setting V grove bit in Cabinet Visi ...
Bob Member
I manage to make work. My drawing was wrong.
Also i wondering what is recommend feed setup for 50 degree V-Groove DIMAR DC-5R8-50S. Right now looks that is moving to slow.
    • CabinetCRUNCHER
    • Cabnetware Support
    • The Millwork Studio
