Subject: Re: Evolution for Buselatto
2/26/15
TomO Member
Website: http://www.stgermaincabinets.com
Greetings,
We have a stand alone PC next to the CNC, (JetXL), for processing drawings and files to send to the router. It has the "office" installation of Evolution 3.3 to use the program editor to look at the files separate from the router. All of a sudden the control editor is sending an error and not starting up, (pdf attached with errors). I have uninstalled and re-installed the program but no help. The PC is running W2000. Support at Casadei had me look for a couple files in C:\EVOL\TMP but the ones Mark specified were not there. Next step from them would be $480 for "Team Viewer" and no guarantee for success. Any ideas from users? Thanks, TomO
Errors.pdf
2/27/15       #2: Evolution for Buselatto ...
Bill Blackmon  Member
Website: http://www.casadei-busellato.com
Hi Tom,
A couple of ideas if they weren't already suggested:
Have you re-installed from scratch? Un-install, delete C:\evol\ and start over?
Assuming the W2000 pc is on the network, how about upgrading it to XP or Win7 with XP Mode? Some updates may have installed that are causing the errors.
Regards, Bill
2/27/15       #3: Evolution for Buselatto ...
TomO Member
Update, thanks Bill for the suggestions. I did try again and one thing I forgot to mention before. When installing I get an error about a file in use "C:\WINNT|System32\ATL.DLL" I have ignored it after retrying a few times. The rest of the install is OK but the program still errors on launching. The computer has not had any updates for a long time and this problem just started last week.
2/27/15       #5: Evolution for Buselatto ...
Try another uninstall, reinstall, delete C:\evol and this time reboot before the re-installation. And make sure no other programs are running (check startup folder) to make sure no other programs are using the atl.dll. That's the extent of my suggestions lest someone mistakes me for an IT guy....
6/30/17       #6: Evolution for Buselatto ...
Steve Modrzynski
Just wondering if this issue was ever resolved? Currently having the same problem with our Busellato, while running it on W2000 as well. Tried re-install from scratch, same issue...corrupted file perhaps? Any info would be much appreciated!
