Subject: Re: HSK-63f tool stand
HSK-63f tool stand
1/28/20
KenW
Looking for input on tool tightening stands for our cnc machine. Need one thats easy and simple but holds up. The new roller lock type look pretty good but my concern is if mounted on machine that sawdust and such could be problematic if operator doesn't stay on top of it. (HSK-63F-ER40 Holder and collet)
KenW
1/28/20       #2: HSK-63f tool stand ...
We have a tool changing bench. I would not mount it on the machine.
1/28/20       #3: HSK-63f tool stand ...
Should be bench mounted, not machine mounted. I tried out an aggregate from Tekniks recently. They sent along a tightening stand that I liked. They have more than one to choose from. The stand we use had to be modified for the aggregates, but newer stands are ready for them.
1/28/20       #4: HSK-63f tool stand ...
dylan bayliss Member
Website: https://www.cnc-tool.com/
We sell both types, including the Techniks and other Mfg
Would agree, a column or table is best to avoid dust contamination.
Call email if questions
Regards
Dylan
Tightening Stand Link
1/28/20       #5: HSK-63f tool stand ...
cabinetmaker
Ball bearing stand and torque wrench. Well worth the money.
We keep all depths and torque settings on a chart right there.
Money well spent
1/29/20       #6: HSK-63f tool stand ...
Chuck Hicks
We can help with that also if needed. We mounted our stand on the vacuum pump frame to get away from the dust if you don't have a bench handy
View higher quality, full size image (1408 X 1349)
1/29/20       #7: HSK-63f tool stand ...
dustmaker1
I mounted one of the roller type on my Rover about 9 years ago and it has worked fine for me ever since. I did put a dust cover on it, mine is a shipping cap from HSD rebuilt iso 30 spindle, fits over HSk 63 F roller stand perfectly.
View higher quality, full size image (1301 X 2061)
1/30/20       #8: HSK-63f tool stand ...
KenW
Thanks for all the replies, will be going with the standard type as that should more than meet our needs. It will be mounted to machine as is the one that's being replaced. When a cutter is changed it is calibrated for length with the machine so having a separate bench area for tool changing is not really needed. Again thanks for all the Input.
KenW
    • Machinery Associates
