Subject: Re: Selexx pal inverter error
6/27/20
Nate Member
Hi all, I just started a job as a CNC operator and finished my second week. At the end of the day I went to spoil the board and the bit hit a piece I had just off-loaded but apparently not far enough. The machine threw an error code "(2064) a6.4 inverter alarm". Everything froze up and would not move for anything. My shop lead came in and was able to reset the machine to get it moving again, but now the vacuum pressure is below 5 psi. I'm not longer at work so I can't check anything, but I'd love to have something to tell them to get it back up and running faster. I saw a previous post on this forum said to check for a blockage at the circulation fan, but I didn't see anything at first glance. I did not feel comfortable taking anything apart since I am so new. Any help would be appreciated greatly!
I also scoured the web for a user manual or list of error codes/solutions but was unable to find anything at all.
6/29/20       #2: Selexx pal inverter error ...
Quicktrim
I have an Anderson router , same parent company, and when I have an inverter alarm it is because the control cabinet has gotten dusty and needs to be vacuumed out. The 24 volt controls should be vacuumed and not blown out as the dust will just compact in there worse if you blow it with compressed air.
Hope this helps.
    • Country Saw and Knife
