Subject: Re: Schelling Panel Saw
Schelling Panel Saw
10/25/22
Color Inc Member
the Company i work for has a Schelling Panel Saw that has a bad power supply. we tried to contact the Mfg about getting a replacement but seems this is obsolete.
thought reaching out here might get me some other options on gettin our saw up and running.
View higher quality, full size image (4032 X 1908)
10/25/22       #2: Schelling Panel Saw ...
Color Inc Member
Its a 1995 FM 202.117
10/25/22       #3: Schelling Panel Saw ...
Send the pics to an electronics repair shop. All the board components are likely to be off the shelf resistors, capacitors, etc. Unless there is something exotic it should be just a diagnosis of each component and replace which should be a routine job for a technician.
10/25/22       #4: Schelling Panel Saw ...
Did you check if that back up battery is good? You can buy all kinds of Chinese power supplies on line. I don't have the skills to help you figure out what to buy.
    • Machinery Associates
