Subject: Re: HolzHer unimaster
HolzHer unimaster
1/28/25
Dave Edgerton  Member
Got a large pod and rail machine and the shop we got it from cut the data cables to disconnect the computer from the machine. Why? Who knows.
Can anyone tell me how to correctly re splice these or if I can unhook the end from the controller and reinstall the cable.
Pics attached
1/28/25       #2: HolzHer unimaster ...
Jim Herron
Strip, solder, and heat shrink the individual wires and heat shrink the bundle
The connectors should have screw terminations inside if you want to replace end to end.
Take your time and get them on a clean, work surface and work them one wire at a time.
Multiple photos will
be your friend
Hope that helps.
1/28/25       #3: HolzHer unimaster ...
Thanks Jim, that us what I was thinking but what about the metal sheathing? How do I get that correct so there's no noise contamination?
1/28/25       #4: HolzHer unimaster ...
Jim Herron
I'd try to cut it clean, pull the braided shielding back, make my heat shrink connections, re-lay the braided shielding and apply a wrap of foil tape, then heat shrink the bundle.
If it gets interference, recable it end to end at the connectors.
One other option is to install a male and female connector in the existing cable that's cut, then the shielding is intact.
1/30/25       #5: HolzHer unimaster ...
Check ebay for cables. If they have them, it'll be easier.
2/3/25       #6: HolzHer unimaster ...
Dave Edgerton
@dropout
I can't believe that these cables would be on ebay. They are $1500 each from HolzHer. The machine is 23' long.
2/3/25       #7: HolzHer unimaster ...
Jim Herron
These are data cables, not fiber optic to the moon.
Do you have a knowledgeable computer repair (not a 16yo working at Geekarama) but a legit business computer repair company or business printing solutions company in your area?
I'm fairly certain they can either repair your cables or build new ones
    • Machinery Associates
