suction box time out or pistons?
3/10/26
Destiny
having issues with suction box sensor or pistons would like some advice or help on how to fix this based on these pictures does anyone see an error? we are having tp suction box timed out also when i try to command the suction box it does not move up or down
3/26/26       #2: suction box time out or pistons? ...
Alex_Zhang  Member
Website: https://yhcncrouter.com/
Hi Destiny,
To give you a more accurate diagnosis, could you clarify which machine you are working on? The term "Suction Box" could mean two very different things depending on your setup:
Option A: If this is on an Edge Banding Machine (Most Likely)
If the error is related to the dust extraction hoods on your trimming or scraping units:
Check the Cylinder Sensors: The "timeout" usually occurs because the magnetic reed switch on the pneumatic cylinder isn't triggered.
Piston Speed: If the piston is moving too slowly (due to low air pressure or a clogged flow control valve), the PLC will trigger a timeout before the box reaches its position.
Option B: If this is on a CNC Router
If you are referring to the vacuum zone control or the spindle’s dust shroud:
Solenoid Valve: Check if the solenoid that actuates the gate is stuck.
Air Leaks: A small leak in the pneumatic line can prevent the piston from exerting enough force to toggle the limit switch in time.
Regardless of the machine, a quick test is to:
Manually fire the solenoid via the PLC output screen.
Watch if the cylinder/piston travels its full stroke smoothly.
Check if the "Input" light on your PLC turns on when the box is in position.
Let us know the machine model, and I’m sure we can help you pinpoint the exact failed component!
Best regards,
Alex Zhang
    • Machinery Associates
