Dust Collection
Subject: Re: Wire vibration in conduit on motor startup safe?
1/27/21
Jared Member
Title sums it up. I've encountered a few machines over the years that, when started, I can hear what sounds like wires vibrating against conduit walls for a few seconds as it spins up. I just put in another 10 hp dust collector running on 208v 3 phase at 30 amps. I have 10 gauge wire running in 1" conduit for about 20' from the breaker panel. A google search tells me 10 gauge wire is rated max 30 amps, but I imagine the draw as the motor starts up is a bit beyond this. The collector sounds and behaves fine, so I'm merely curious about wire jump in the conduit. Any thoughts on this?
1/27/21       #2: Wire vibration in conduit on motor ...
Im no electrician but consider myself pretty savvy but you often see heavy start loads specifying far larger feeds and breakers than the running amps. We have a compressor that specifically calls out a wire feed and breaker size twice that of the nameplate amperage of the motor. (motor rated at 40a and manufacturer spec's 80a breaker and feed).
Heavy/long pulls on the start in my experience typically run the feed a substantial amount over the nameplate not right at the motor rating.
1/30/21       #3: Wire vibration in conduit on motor ...
Heck, wire jumps in the pipe when I turn my lights on in the morning.
It's just moving, nothing to be concerned with from that perspective.
Whether the wire is the right size, I have no clue. I'm electrically retarded, and consider changing a cord end taking my life into my own hands.
2/5/21       #4: Wire vibration in conduit on motor ...
Chris
Get yourself a multimeter so you can measure the amperage during start up.
The breaker is not tripping so you should be fine
    • RT Machine Co.
    • Denray Machine
    • Sandman Products
    • Machinery Associates
    • GreCon
    • American Fabric Filter Co.
