Subject: Re: Air compressor
Air compressor
7/16/15
Stefano
I wonder if someone can suggest me about a problem i having with my 2hp induction motor air compressor. Last week the compressor shotted down the 15 amps circuit breaker, I turned on the circuit breaker then the compressor did run for few minutes then the circuit breaker shotted down again. Since the compressor can run on 20 amps circuit I connected the compressor to 20 amps circuit and then when the compressor did reach 80 psi shotted down, this time by the protection on the motor itself (the red button on the back of the motor) . I called the compressor company and they told me that it was a problem with the motor and they sent me the motor that i installed today but I have the same problem. The pump turn freely by hand so I, don't think is a pump problem, the compressor turn of to 80 psi all time but it isn't a problem from the regulator because any time the compressor stop still has the electric power coming from the regulator (I call ''regulator'' the device that stop the compressor when the compressor reach the max. pressure )
Thank you
Stefano
7/17/15       #2: Air compressor ...
Jim Member
Check the piston relief valve. When the compressor stops, there should be a small hiss of air being released from the cylinder. If it doesn't, the motor will have a very hard time of trying to turn the piston because of the pressure still on it.
This happened to me. Wound up replacing a $250.00 circuit board twice and a new motor until I figured it out. Not the techs.
7/17/15       #3: Air compressor ...
Stefano
Thank you Jim, and were I find the piston relief valve?
7/19/15       #4: Air compressor ...
JP Member
http://fix-my-compressor.com/the-air-compressor-unloader-valve/
