Subject: Re: correct primer under pigmented water based Lacquer?
2/27/17
Robert Member
Website: http://rprbuilders.com
I used a gray pigmented water based Lacquer to prime under white-based, pigmented white water based lacquer.
I'm using SW Kem Aqua.
I've used the product 6 times so far , always with a beautiful, opaque finish.
On this project, after 6 coats of white, I still have gray shadows.
I'm spraying with an Apollo hvlp rig that I really enjoy using.
And its only inside the cases. All the flatwork is opaque.
All the pieces are the same material.
Obviously, I've done, or am doing, something wrong.
I've used the product in the same way on previous jobs with great results.
None of the other projects were white top coats. They were darker colors.
I'd love to be schooled. Thank you for sharing your thoughts.
2/28/17       #2: correct primer under pigmented wate ...
denny jahnz
Use a white primer. They have a product called a WB surfacer. Use that and then one more coat of Kem Aqua.
Either your coats are very,very thin, you aren't getting a full coat or the lighting is playing tricks on you. 6 coats would either cover everything or nothing. Not sure how else you would get what you described.
Once again for clarity- you self primed with gray Kem Aqua and then you sprayed 6 coats of white Kem Aqua over that?
Can you post pictures?
2/28/17       #3: correct primer under pigmented wate ...
david zaret Member
i use shellac-based primer under the kem-aqua pigmented. you should need no more than two coats of the KA to achieve a good finish. FWIW, i find that warming the finish and substrate helps a great deal with KA.
good luck with your project!
2/28/17       #4: correct primer under pigmented wate ...
Puzzleman Member
Why would you use a darker color to prime under white?
I use flat white before I finish it with a colored lacquer.
2/28/17       #5: correct primer under pigmented wate ...
Robert Member
Thanks everyone for the posts.
I'm headed back to SW for more material and I'll ask about the surfacer product.
I used the gray because I had over bought it on a kitchen that was all gray (don't ask me, that's what they wanted.)
It worked great on a green TV wall and a blue bench....but it is sucking on a white bookcase.
And I'll never do it again.
And I've never gotten good coverage with one or two coats of pigmented lacquer - am I being to scared of drips and runs and spraying too light? Speaking of light, my booth has flourescent lighting, and there's like 6 different shadows everywhere.
Suboptimal when doing a reflective coating.
The Kem Aqua does hold well to vertical surfaces, but I feel like it's better to apply another coat than sand mistakes off.
My bad, and I'm moving forward.
2/28/17       #6: correct primer under pigmented wate ...
Denny J
I have been spraying WB for nearly 20 years and Kem Aqua has some of the worst vertical sag resistance that I have seen.
Lots of better products that allow you to spray a much heavier coat without runs.
2/28/17       #7: correct primer under pigmented wate ...
Robert
To Denny G - I'm using the SW product because of the solid color.
I usually use either a general finishes product or Hydrocote resisthane for clear coating.
I'd love to find a product like the Hydrocote with 60 g/l of voc's that I can tint a solid color. People seem to want colors right now.
2/28/17       #8: correct primer under pigmented wate ...
Denny J
Try the general finishes poly. They make that in white and can tint to any color. Hands down better product than Kem Aqua for spraying on site. Use their primer as well.
2/28/17       #9: correct primer under pigmented wate ...
jbateman Member
Since it's only inside the cases you might be getting too much blowback, where the coating is not getting into the corners.
2/28/17       #10: correct primer under pigmented wate ...
vince
You guys should try Valspar's Zenith line of paint. I used General for years but the price and shipping was getting out of hand. Zenith is cheaper and has higher solids. Sprays good also.
