Subject: Re: looking to achieve that NC look on walnut using WB
10/25/17
Thom
I'm finally going wb but need to match the doors that look like what my Duravar(or nc) looks like on walnut. Is there a transtint dye or mix that I can add to aguatana to emulate that?
10/25/17       #2: looking to achieve that NC look on ...
Thom
Dude, you're never gonna make that wb look as good as your cv finish
10/25/17       #3: looking to achieve that NC look on ...
Thom
I have to find a solution. I'm spraying in a parking lot now, but still have high standards on quality finish. There has to be a way to make wb look good
10/26/17       #4: looking to achieve that NC look on ...
Zinsser sealcoat. Add amber Transtint dyes if you want. The seal coat pops the grain.
10/26/17       #5: looking to achieve that NC look on ...
RobertJ
Valspar makes an 'amber' sealer waterborne lacquer coating in the Zenith line. Use of a yellow dye can help in lieu of above for walnut. Make samples.
10/26/17       #6: looking to achieve that NC look on ...
Michael Foscone  Member
They have been trying for over 40yrs, ain't gonna happen. WB is getting better, but that's it.
10/26/17       #7: looking to achieve that NC look on ...
John Member
I've been using mostly General Finishes WB products for about 8 years. You can get any look you want and the final result looks as good as solvent based (at least to me and my small group of customers) if you are willing to do some extra steps. As mentioned above, a coat of Sealcoat shellac really helps to give WB a solvent based look; other times adding Transtint dye to the finish is the right move. No one answer is universally correct and you have to be willing to make specimens and adjust to get the look you want. I've done quite a bit of work matching old finishes and that can get pretty involved; dye, stain, sealer, toner, glaze, sealer, another toner to adjust, topcoats, but so were many of those original finishes, and I've always been successful. If you are just trying to replicate the look of a solvent based clearcoat you should be able to get there w/o a world of trouble, but you may need to try a couple of different clear coats to find one that is closest to start with, and then be willing to add whatever extra steps are needed to make it look the same. If I could pick only one WB topcoat it would be GF's Enduro Clear Poly. It's dead clear so you can adjust the color if needed, sprays like a dream, and is very scuff resistant and quite chemically durable. I'm sure there are others; this is just the one I know really well.
John
