Subject: Re: RE: Organic Water-based Finishes
8/12/19
Tommy
Is there any organic water-based product that would replace volatile chemical finishes such as lacquers and other toxic finishes, and enhance the grain of hardwoods like a tongue oil would?
8/13/19       #2: RE: Organic Water-based Finishes ...
DannyB Member
It's really really hard to tell what you are looking for, without you saying what you think organic finishes are.
A lot of water based finishes have fairly harmful-to-people chemicals in them.
VOC is not about harmful-to-people chemicals, it's about harmful-to-environment chemicals, which is not the same at all
Pretty much everything you smell in this world is a VOC.
If you give the exact parameters of what you want, happy to try to help you find something!
8/14/19       #3: RE: Organic Water-based Finishes ...
Pine tar?
8/14/19       #4: RE: Organic Water-based Finishes ...
Jonathan Mahnken
Le Tonkinois is the only finish I know of. Great stuff. Expensive. Slow drying
8/14/19       #5: RE: Organic Water-based Finishes ...
Jonathan Mahnken
Not waterbased though
9/2/19       #6: RE: Organic Water-based Finishes ...
Larry Schweitzer Member
We've WB finished for a long time. I've never seen a WB finish that looks like it has been oiled. I have no idea of what an "organic" WB finish is? Please explain. The resins in most(?) WB finishes are some form of plastic. The carriers usually contain alcohols, & other solvents that are permitted by the "rules." The closest finish I can think of to what you are looking for is shellac. Bug excrement and alcohol (sort of.) The "natural" I. E. non-bleached will give a yellowish orange finish. Not terribly durable but easily fixed.
