Subject: Re: Stretch wrap residue on paint.
6/29/21
Steven
Has anyone else had a problem wrapping parts with stretch wrap and know how to remove these marks?
The paint is a waterborne urethane trim enamel that had been curing for about 7 days before being wrapped. The wrap had been on for about 16 hours when this picture was taken.
I've tried wiping with a paper towel wetted with naptha which didn't affect the paint but didn't remove the marks either. Also tried with DNA which immediately left a haze in the paint(bottom right of pic) and didn't remove the marks.
Is this just residue from the stretch wrap or a chemical reaction with the paint that can't be removed? Any replies appreciated.
View higher quality, full size image (1865 X 2144)
6/29/21       #2: Stretch wrap residue on paint. ...
R Statham Member
Is the product from SW? I have issues with their waterbone urethane curing.
After 7 days I have had moving blankets leave and impression in the finish, especially in dark colors. Dry to the touch, but not fully cured. It takes quite a while to fully cure (30 days I think?). I am thinking of experimenting with some other manufactures to compare differences.
6/29/21       #3: Stretch wrap residue on paint. ...
Steven
This is SW Emerald urethane trim enamel. I've had the same problem with both satin and semi gloss, and it does seem to have more of an effect on darker colors, but I've noticed it some on whites too.
I also use stretch wrap over foam padding and the foam doesn't leave an impression in the paint after 24-48 hours of curing which is why I'm wondering if it's residue from the stretch wrap or a chemical reaction. The marks don't appear to be pressed into the paint like it was still soft; they look glossier than the rest of the surface.
6/29/21       #4: Stretch wrap residue on paint. ...
Steven
I was mistaken. I just unwrapped some pieces that had been curing for 7 days that had some foam on them and it did leave a very light impression on the surface. Looks like I'll have to stop using this paint though it seemed to be pretty durable; even after a couple days light scuffs during install could be wiped off with a damp cloth and it was harder to scratch than other waterborne paints I had used. Seems odd that it's resistant to scratches and scuffs after a couple days, but able to put imprints in it after 7.
6/29/21       #5: Stretch wrap residue on paint. ...
R Statham Member
That's the same product I have been using as well. I started using it a few years back, and seemed like a really good product, lately I seem to be having more issues with it. Just sprayed a job that was a light color in satin sheen, when it was dry it felt gritty. I had to re-spray the same color in semi-gloss to make myself and the client happy with it.
6/29/21       #6: Stretch wrap residue on paint. ...
rich c
What humidity and temperatures are you seeing during the curing? This time of year isn't helping you. Also wet film thickness makes a big difference in curing. How thick are you spraying?
6/29/21       #7: Stretch wrap residue on paint. ...
Steven
This afternoon RH in the shop was about 55% and temperature 92 degrees. Been getting a lot of rain the past month, but the week these were drying was mostly sunny and hot; maybe a couple days of rain.
I spray with Graco and Titan airless rigs and use a titan 410-412 fine finish tip for primer and topcoats, mostly. I don't often measure mil thickness but don't spray with a heavy hand or box coat so just an even wet coat. One solid coat of primer, two top coats of paint. I spray a lot of fully assembled cabinets upright so can't do heavy coats or risk getting runs and sags.
In my experience I'm finding too that the satin finish doesn't feel nearly as nice as semi-gloss, though it looks nice. Pro classic latex satin definitely feels a lot smoother than this paint's satin, but scratches and scuffs easier during install.
6/30/21       #8: Stretch wrap residue on paint. ...
Ed
Had the same issue with a walnut side table with SW conversion varnish. changed from medium rub to a high gloss under stretch wrap. Tried to fix on site with no luck.
Took back for refinish. So for painted fronts, I now cover in wax paper then stack and wrap. Works on the water based finishes like BM advance,
