Subject: Re: final finish for tables
6/28/22
karen beach
Website: http://www.centralcoastlumber.com
Looking for advice on using a waterbased finish over a Rubio Monocoat or Tung Oil application. My Purpose is to add sheen and durability including a vapor barrier over tables that are built from solid slabs.
The question being will i run into any issues if i apply "Lorchem Germina 60" over a dryed but not yet cured Rubio or Tung Oil?
6/28/22       #3: final finish for tables ...
Combining a different material on top of another material is a recipe for disaster.
6/28/22       #4: final finish for tables ...
JeffA
In my experience, the best moisture barrier comes from using a vinyl sealer. But you aren't telling much of what kind of environment this finished product will be in. Will it be outdoor without any kind of cover? Or under some kind of canopy. These are huge differences.
Care to give more detail?
6/29/22       #5: final finish for tables ...
Why not just get away from the rubio and run a conventional finish? Many finishes look just as good as rubio. I thought I read somewhere rubio expressly says no finish allowed over top?
Seems like a lot of work/risk just to use the trendy finish.
6/29/22       #6: final finish for tables ...
Matt Calnen
A lot of the work I have been providing to a higher end contractor is being finished with Rubio Mono Coat. For areas that will see water, like countertops, the flooring contractor has been putting a Bona product on after 30 days. The flooring contractor, a friend of mine, has contacted both Bona and the tech said after thirty days you can top coat.
Have had luck so far after 2 years of doing it.
6/29/22       #7: final finish for tables ...
Im just not sure I see the reason to go to the extra step of rubio (which is already a labor intensive finish) and then to apply a film finish over top which would pretty much negate/mute any of the brilliance and alure of the rubio in the first place? It doesnt seem to make a lot of sense other than to have a "rubio" finish.
Several shops have shown me rubio samples that in all honesty are pretty much indistinguishable from a good stain/film finish and we are done in 1/3 the time without even considering a need to wait 30 days for a top coat.
Im just not sure I see the sense. Bona is just a 2k iso waterborne clear and unless you run gloss (no flattener) your going to mute any brilliance the rubio leaves behind and even with the gloss you will lose some.
Seems like just blasting a shop sprayed 2K or even a stain/finish routine in the shop using Bona would be much better. The big drawback with Bona is being a flooded finish its so thin it doesnt hang at all on vertical surfaces so its a bear and while we've sprayed it several time, its just easier to spray a proper 2k and be done.
6/29/22       #8: final finish for tables ...
I agree with Mark. You would be better off using Zinsser Sealcoat shellac to pop the grain and it seals against water. Then going with a WB 2K for durability.
As Mark mentioned if you are a pro use a pro wb. If you are a consumer, flooring guy, or don't know what's available use Bona.
7/5/22       #9: final finish for tables ...
Matt Calnen
The reason to topcoat the Rubio with Bona is to keep the color and look the same as other areas that just have Rubio.
Sure you can get a similar looking finish with other products, but I think decorator’s and architect’s spec Rubio because they like the look and feel of it. It does have a great feel to it. That’s what separates it from a stain and film finish job. Is it a better overall finish? I would say no, but If that’s what they want, why not give it to them?
7/5/22       #10: final finish for tables ...
Couldnt agree more with give them what they pay for and I guess I was thinking of a piece that was completely being finished in rubio and then completely top coated... it negates the rubio other than for the namesake which again, if the arch/designer/customer insists, then it is what it is.
Work partially left rubio alone and then part (wear surfaces top coated) I guess I just dont get but your correct, if they want what they want then take the cash.
7/5/22       #11: final finish for tables ...
Some of those river table guys go over the Rubio with a ceramic clear coat. They claim it’s extremely durable.
At the end of the day, if they like the look and perceived durability of Rubio/Bona and you aren’t aware or having adhesion issues then give the customer what they want.
7/6/22       #12: final finish for tables ...
I also agree to give them what they want to a point. If there is the slightest hesitancy about adhesion, spell it out on the contract and don't provide a warranty. Designers and architects are not experienced furniture finishers.
7/6/22       #13: final finish for tables ...
Edit of my previous post. Designers and Architects will be quick to dismiss any responsibility if the finish fails. The blame falls squarely on the shoulders of the company that applied the finish. I've had it happen.
7/6/22       #14: final finish for tables ...
