Subject: Re: PPE When Spraying
PPE When Spraying
12/28/23
howard
Website: http://woodcontours.net
I thought I would check in on this. I have a small spray booth. I don't spray a lot but when I do I wear a good quality 3M half respirator. What I wanted to check on is I wear a Tyvek zip up suit, do you wear any type of coveralls? Thanks
12/29/23       #2: PPE When Spraying ...
Mastercabman
I usually don't
But I do blow air all over me before I get started
I have 2 dogs with long hair and sometimes I'm reminded that maybe I should wear a tyvek suit!!!
12/29/23       #3: PPE When Spraying ...
tom gardiner
I wear a nylon coverall with anti static threads woven in. I bought it to reduce the odor on my clothing from spraying. I noticed a big improvement in the amount of lint caught in the finish. The CV I spray gets a static charge when blowing off. It was drawing crud off my clothing. The static discharge ability of the coverall cured that.
The brand is Airmix.
12/29/23       #4: PPE When Spraying ...
Oth
I never understood why folks wear those half masks, leaves your eyeballs wide open for all sorts of over spray and whatever is floating around. Before I got my supplied air respirator I always wore a 3m full mask. As far as other covering I usually have a heavy duty apron and nitrile gloves. I've thought about the tyvek suits but seems like a hassle for the amount I spray, not in the booth all day.
12/29/23       #5: PPE When Spraying ...
Richard Mellor Member
I also wear an antistatic suit and a air-supplied respirator. The suit was the best $70 I have ever spent on improving the quality of my finished parts.
Like Tom said, no more curd in the finish, clean clothes, and not smelling like the spray booth for the evening with the family.
https://https://www.workingclassclothes.com/search.php?mode=search&page=1&keep_https=yes
12/29/23       #6: PPE When Spraying ...
It would be helpful to know what you are spraying. You need a lot of protection for 2K finishes compared to shellac. And as mentioned a 1/2 mask is forbidden on that kind of finish too. That finish loves the moisture of your eyes.
12/31/23       #7: PPE When Spraying ...
Bill Colligan Member
I saw a 3M bulletin recently acknowledging that no cartridge made by them will protect you from the isocyanates in 2k finishes. An air-supplied respirator and full suit is a must.
1/26/24       #8: PPE When Spraying ...
Nick Sinderson
I've been using Gemini/Sirca's waterborne 1k/2k polyurethane for a couple of years. They claim that their isocyanate hardener/catalyst molecule is too large to be absorbed through the skin and all that's needed (l'm paraphrasing now) to stay safe is to use in a well ventilated booth and a respirator. Of course l take this information with a bit of skepticism so l cover-up when in the spray booth spraying this product catalyzed; long pants, long sleeves, gloves and a full face respirator.
Also, (so far) l'm more than happy with the product. Not quite the smooth touch or clarity of the CV I've been using for the last 10 years but it's real close. So close in fact that not one of my customers have noticed a difference.
