Kremlin vs HVLP Finish Quality
6/24/19
Jordan Member
Looking to get some feedback on the Kremlin Airmix AAA vs conventional HVLP when it comes to finish quality. I mostly do custom pieces so I am not doing high volume. Typically spraying one piece at a time, 2-3 times a month. The price of the Kremlin is not an issue and the main goal is to get the highest quality finish I can. Question is, will I notice a difference in quality stepping up to the Kremlin? Any other methods/products I should be looking at? Currently using a DeVilbiss Tekna Pro conventional gun. Thanks all!
6/24/19       #2: Kremlin vs HVLP Finish Quality ...
Pat
The general answer is no. The main reasons for going to AAA are speed, convenience and the ability to spray with a lightweight gun at any angle (although this can be achieved with a pressure pot).
There are exceptions, I'm sure, depending on what you're spraying, your booth, etc., but a good quality conventional rig can achieve results just as good as AAA.
For the record, I use an AAA for almost everything and I love it.
Cheers,
Pat
6/24/19       #3: Kremlin vs HVLP Finish Quality ...
Jim Clark
Just for everyones info:
DeVilbiss makes a bag kit to fit most all top
cup HVLP guns where you can use a plastic
bag inside the cup which enables you to
spray upside down and never spill, also
making clean up much easier.
1 qt. Zip-Lock freezer bags works just as
good as the Devilbiss bags.
Reference
https://www.ebay.com/p/DeVilbiss-Dev-EZ-Liner-Kit-OMX70K48/1511821738
6/24/19       #4: Kremlin vs HVLP Finish Quality ...
herb johnson
for a the best finish give me a binks 7 gun or a devilbiss mbc gun
there is reason they are still being made after about 40 years
good luck
herb j
6/24/19       #5: Kremlin vs HVLP Finish Quality ...
Nick
+1 for what Herb said.
6/25/19       #6: Kremlin vs HVLP Finish Quality ...
Jordan Member
Great info, thanks all! I'm going to look into that mbc gun.
6/29/19       #7: Kremlin vs HVLP Finish Quality ...
Big Kremlin Fan
Spraying for almost fifty years now. I still have maybe five or six Banks Model 7 guns. Learned to spray with them and would sworn nothing could ever be better.
Well, guess what? I've never picked one up since the day I first pulled the trigger on my Kremlin AAA about 10 years ago. It fits the hand like a glove, an extension of your fingers and super light. Minimizes overspray by tons. Finish levels out much superior to any Binks #7 ever did. The savings in lacquer volume have paid off my Kremlins in less than one year.
Kinda drifted here, I believe the question was Kremlin vs HVLP, so not sure how Binks Model 7's came into the picture, but I figured I'd respond to that part of this thread. And I respect every person posting here - we're all family and that's big in my book! So, that's my story and I'm sticking to it!
7/1/19       #8: Kremlin vs HVLP Finish Quality ...
Robert M  Member
I'll second "Big Kremlin Fan" !!
Not been spraying for.....50yr, but, 20 ;o) !
Regardless time (past experience), in my noble opinion, no comparison as for ease & virtue of spraying with a AAA ( kremelin or CAT or....any brand for that matter !!)
Sure, gravity guns with a 3M ppm is flexible and gives a fare to excellent spray finish.
I'm one of those who stand by,,,,,,it not the equipement that make the finish, it's the who.....how YOU adjust to your equipement & material !
Sure, no debate here, AAA are best for many reasons ( 1st, the least for over spray, therefore, less bonce back in tight corners or closed space) second, spray is better by a pressure pump pushing fluid vs air pressure (gravity or siphon) .
All & all, 99% of AAA owners / users will tell ya.....stay with a gun VS AAA, unless it's a budget restriction thing !!
All the best
7/8/19       #10: Kremlin vs HVLP Finish Quality ...
Kevin
I would never use a kremlin AAA if my production goals consisted of one piece every couple months.
The ammount of cleaning and maintenence of the fluid line and seals would kill the entire concept.
I am a huge kremlin fan. But the quality youre looking for can be achieved with a $20 harbor freight gun and proper application knowledge.
Buy a pump if it makes u feel better, but a very nice spray gun and properly applied mechanics will solve your limited production rate much more suitably.
Use the proper solvents to meet the desired effect on your coatings.
Air assisted airless is a production must.
But its overkill for a couple projects a year.
7/8/19       #11: Kremlin vs HVLP Finish Quality ...
mastercabman
I agree with Kevin on this one
Pumps are great and expensive so you need to put your investment to work
So if you spray a lot and you need speed the pump is going to be your best choice
I also don't do a whole lot of spraying
I use CAT guns(PPS and pressure pot)and I get excellent results
Maybe if I get a descent size job I'll invest in a pump
7/8/19       #12: Kremlin vs HVLP Finish Quality ...
Nick
Small projects 2-3 times a month, with the quality of your finish being #1. I would mate a Binks SG2 2 quart pot, 15-20' of air/fluid line and either a Devilbiss Compact or Teckna Pro-lite pressure feed gun and a assortment of needle/nozzles. Retail new this will set you back around a $1,000.00, but last for years and years...if you keep them clean.
7/21/19       #13: Kremlin vs HVLP Finish Quality ...
Denny J
I ran AAA sprayers for nearly two decades ranging from Asturo to CAT to Merkur and I love the way they operate and spray but around 6 months ago when I switched to 2k poly my rep dropped off a Titan 655d diaphragm airless to test. It has a hopper on top which is so much nicer than the pickup tube and it is smoother than the typical piston pump airless plus you can use a 25' 1/8" hose which is actually more ergonomic than the twin hose AAA.
I actually sold both of my AAA and replaced them with the Titans and their cost is under $700 each.
