Kremlin Cleaning
2/28/20
Mike Member
Hello group! I would like to know how you go about cleaning your Kremlin pump system when you are finished spraying water-based clear and pigmented finishes.
I'm presently using Citra Clean but the cost of it is very expensive. Since I'm using Sherwin Williams Kem Aqua Plus I called tech support and they suggested using R6K25 but I just wanted to run it by the group and find out what your experience is.
Thank you!
2/28/20       #2: Kremlin Cleaning ...
Shane Welch
We change back n forth between solvent and water... clear & pigmented all the time through the same pumps/lines. if your equipment is always clean then you will never have issues going from water to solvent vise versa or pigmented to clear as long as your flush habits are up to snuff.
lets say your currently in pigmented water.... flush with water until running clean.... pump out water... pump in with acetone and circulate through the pump/lines.... pump out acetone and pump in polychem acrastrip full strength. let the poly chem sit until your next session.. next day.. next week next year its ready to roll. poly chem is expensive but if your pumping in and pumping it out clean it can be used over and over and over.... I have a video on youtube of me explaining how to flush a pump thoroughly..
2/28/20       #3: Kremlin Cleaning ...
Terry V Member
Website: http://www.woodshoponshilling.com
How do I access your YouTube video?
2/28/20       #4: Kremlin Cleaning ...
Mike Member
Shane Welch, please post a link to your cleaning video. I'm always looking for good info. Thank you!
2/28/20       #5: Kremlin Cleaning ...
Shane Welch
gimme a few minutes and i'll post the link..... i'm not an expert speaker...lol
2/28/20       #6: Kremlin Cleaning ...
Shane
Here is the YouTube link to my way.. I made it for someone on here a while back.
https://youtu.be/LRESZUDjzFk
Pump flushing vid
2/28/20       #7: Kremlin Cleaning ...
Mike Member
Shane Welch, excellent Kremlin cleaning video!!! Fast and easy and I like the way that you verbally specify length of time leaving the polychem acrastrip in the system. Thanks for posting.
2/28/20       #8: Kremlin Cleaning ...
Going from water to solvent. Pump hot water through until clear. Then pump Denatured Alcohol through which will absorb any water left in the lines.
Before you go to solvent run a little wash thinner through the lines.
2/28/20       #9: Kremlin Cleaning ...
Mike Member
Thank you Leo.
2/29/20       #10: Kremlin Cleaning ...
Mike Member
Shane Welch, would you please post a picture of the polychem acrastrip container and who you purchase it from?
Thank you.
2/29/20       #11: Kremlin Cleaning ...
Shane
Here is the pic and currently I get supply from AirPower.
2/29/20       #12: Kremlin Cleaning ...
Mike Member
Thank you Shane, for the info!!!
3/1/20       #13: Kremlin Cleaning ...
Just enquiring on what your recommendations are if you are only spraying water based products and you are not going to be using your pump for quite awhile. Do you leave water in the hoses and pump or do you put something else in?
3/2/20       #14: Kremlin Cleaning ...
Mike Member
Scott, get the water out and put in polychem acrastrip. Leave it in there until you spray again even if it's a month, six months or a year. If you go through cold winter months make sure your Kremlin is in a warm area 55 Fahrenheit or slightly above. Before you walk away from your Kremlin make sure your piston is down. I'm sure Shane will back me up on this. Check out his video above. Hope this helps!
4/23/20       #16: Kremlin Cleaning ...
Al
How much does a 5 gallon can of the cleaner cost ?
