Kremlin One Pass Paint Heater
4/28/20
Mike Member
Is it recommended that someone who is spraying waterborne lacquers should remove the mixers from the Kremlin One Pass paint heater? http://notices.kremlinrexson-sames.com/prod/notices/575.019.190/fold/notices/57804
5120-UK.pdf
Thank you.
4/28/20       #2: Kremlin One Pass Paint Heater ...
Brewster
Hello Mike my Kremlin service rep also recommend removing the mixers if using WB topcoats. They removed them before shipping to me
4/29/20       #3: Kremlin One Pass Paint Heater ...
Mike Member
I believe my mixers are still in and I need to call the factory to see if I need any gaskets for reassembling. Thanks for your input!
4/29/20       #4: Kremlin One Pass Paint Heater ...
herb johnson
run some acrastrip thru it and get a pair of needle nose pliers
good luck
herb j
4/30/20       #5: Kremlin One Pass Paint Heater ...
Mike Member
I have been delaying removing the mixers because I wanted to make sure I could get new seals. I did contact Sherwin Williams yesterday who I purchased the heater from and they tell me they can get new seals if needed. I also contacted Kremlin tech support and they are pretty sure and since my paint heater is only a couple years old I might be able to get away without replacing the seals. They also suggested that I put it back together with some heat resistant soluble grease. So with this information pretty soon with the help of my friends torque wrench I'm going to strip the whole unit and give it a thorough cleaning after removing the mixers. Did you know they are not making the OnePass heater anymore and the company went out of business according to Kremlin.
