Painting oak
5/29/20
Kip Stevens
Website: http://covenantcustomcabs.com
Ok guys, I’m a Cabinet maker with little finishing experience. My bride wants to paint our oak cabinets that I built in 2003 but we don’t want to see the grain. I’ll be replacing the crown and the doors so we’ll just have to deal with the outside of the boxes. What is the best way to fill the grain in Order to get a good, fairly slick finish? The cabinets are red oak with minwax polyurethane. We will be brushing an oil based paint for our new finish. Thanks
5/30/20       #2: Painting oak ...
rescraft
Get another bride? Just kidding. Any professional finish line offers a grain filler. Observe traditional finish rules, clean, prep, grain fill, sand,prime and paint.
It's alot of work, but think of the bonding experience you will get working together :))
5/30/20       #3: Painting oak ...
Mastercabman
Since you only have to do the boxes
I think you'll be fine
A lot of people will suggest a couple coats of shellac and then paint
I've seen it before and not too impressed
The best look I ever had was to use a product called "timbermate"
It's a water based putty/grain filler
You can add a few drops of water and make it very thin
Just put it on,let it dry,sand,prime and paint
For me I use solvent based finish
I would put 2 coats of white vinyl primer and 2 coats of pigmented top coat
Good luck with your project
5/30/20       #4: Painting oak ...
First I'd scrub them with TSP and a stiff brush. If the pores are open enough to show, they are open enough to have cooking oils in them. Then drywall compound, sand, more compound, sand, then a heavy fill primer, sand again, then paint.
6/1/20       #5: Painting oak ...
Jared E
Maybe I'll get crucified for suggesting this, but if they're frameless boxes, why not just reband with a non open-grain banding like maple or birch? A case could be made that by the time you're done mucking about with one or more coats of grain fill, you could've refaced with new paint grade banding.
