Refinishing
2/27/21
Chris Payne
I have just installed a new quartz top on a set of existing cherry cabinets. Cabinets have been in home for 22 years and the finish is looking pretty dull wore off in a few places. They want me to do something to bring some shine back but I am thinking that they have conversion varnish on them but not real sure. If it is and I sprayed the doors can you brush that on the cabinets with a brush? I'm thinking not.
2/27/21       #2: Refinishing ...
mastercabman
I've done it before
Cabinets wasn't too bad,there was some spots that needed to be touched up with a marker
I then used a pre-cat like Magnaklear from MLC
Sprayed the doors and the cabinets
Doors were done in my trailer and the cabinets on site
There were not that much to do so it was easy to control the spraying
2/27/21       #3: Refinishing ...
Chris Payne
Is that Magnklear a conversion varnish and I don’t think spraying in this house is a option.
2/27/21       #4: Refinishing ...
rich c
Hire a finisher and then mark up their estimate and charge the customer. Refinishing is not easy, there will be a ton of surface contamination from cooking oils and grease, and it sounds like you don't have a lot of experience with finishing.
2/28/21       #5: Refinishing ...
mastercabman
Chris
Magnaklear is a pre-cat
Nothing wrong with spraying inside a house if you seal everything off
2/28/21       #6: Refinishing ...
Chris Payne
So you are saying that the magnaklear would be OK over a conversion varnish if that is what it is??
2/28/21       #7: Refinishing ...
mastercabman
Yes
Pre-cat over post cat good
Post cat over pre-cat no good
It's ok to put a softer finish over CV
But never put a hard finish over a softer one
But don't forget to Scuff sand and wipe/blow dust
