Lacquer sanding sealer
9/30/21
Sam Winters Member
Website: http://www.goldbugproducts.com
I recently found out that Mohawk has discontinued their Industrial Sanding Sealer #610-1607. I spoke to them and they can recommend nothing to replace that product other than their Vinyl Sanding Sealer which is a very different product. Does anyone here know of a similar product that is still available from a different source?? Nitrocellulose based, very high solids, very fast drying time. I've been using this product since the 80's and really don't want to switch over to the vinyl sealers. Thanks in advance, Sam
10/1/21       #2: Lacquer sanding sealer ...
Chemmy
Sam look for a company that sells Behlen bros lacquers, (Qualalac sanding sealer)...lacquers. or google the product. Woodcraft use to carry it, but not sure if they still do or not.
YOU may also find they carry Behlens qualavite gloss alcohol proof lacquer also..both tested brands and have been AROUND since the 1950's...
10/1/21       #3: Lacquer sanding sealer ...
chris
https://www.camger.com/wood-finishing
they make a full line of nitro lacquers
10/1/21       #4: Lacquer sanding sealer ...
ML Campbells still sells a lacquer sanding sealer.
https://www.mlcampbell.com/product/designrclassic-sl-furniture-lacquer-sealer/
10/1/21       #5: Lacquer sanding sealer ...
Sam Winters Member
Thanks for the suggestions. Behlen and Mohawk are the same company. The MLCampbell product looks interesting but I'm a bit confused by the description...says available in 4 different toners and is intended for refinishing?? Regardless, Thanks!!
10/1/21       #6: Lacquer sanding sealer ...
Sam Winters Member
It looks like Sherwin Williams has a similar product....Sherwood LOVOC lacquer sanding sealer..their number T60 F 64.
10/1/21       #7: Lacquer sanding sealer ...
Chemmy  Member
Well on the surface your right, Mohawk
And Behlen's are within the same RPM CO.
Just as Star Chemical and others they purchased to make up their monopoly of touch up and repair and best finishes inventories.
But unless they changed the original formulas of the qualivite finishes, they are still " Behlen" products at heart.!
That said, SW has good products also, in the nitro family, have had good success with them.
But I will remain a solvent acrylic user as I have been since the 90's. Nitro's have their place for sure, especially in refinishing and matching those amber colors needed to duplicate their aged appearence. And their fast dry characteristics for sure, but for modern work, especially colored work or other work that needs to not yellow, there is nothing better....IMHO.
Hope things work out for you though, best of luck.
10/2/21       #8: Lacquer sanding sealer ...
Bob Niemeyer  Member
Sam, Looked at your website to see what you do. Here is the company you need to buy your NC from. I see you do Guitars and he also has the NC you will want for that.
Talk to Jerry @TTC Coatings,I will post a link. Tell him my name as that will get you "in the door". You will have to buy in five gallon pails I believe, just ask if you want gallons.
The lacquer he makes blows away every brand in this thread as I have tested them side by side. Also his NC has no problems with mohawk stains and glazes.
http://www.tntechcoatings.net/
10/4/21       #9: Lacquer sanding sealer ...
Glen
We went through the same issue and now use Duralaq lacquer and sealer.
10/5/21       #10: Lacquer sanding sealer ...
Steven
200-0012
550 VOC Gem Coat High Build Clear Lacquer Sealer
If you go to their website and search for that product you can look at the sds or pds.
Gemini Coatings
10/13/21       #11: Lacquer sanding sealer ...
Peter
You do not want ANYTHING made or marketed by Behlen. It is homeowner grade cockypoo! Tries it once yearsw ago not nowing any better and really enjoyed scraping it off with a razor blade everywhere water touched. You also don't want SW vinyl sealer as it doesn't powder it gums up. Really enjoyed wet sanding a whole project bcause of it. Somebody has to carry good old laq sanding sealer. Maybe MLC?
10/13/21       #12: Lacquer sanding sealer ...
Bob Niemeyer  Member
Peter, You want a very good NC Lacquer see my link above. This NC works like no other on the market and is very durable. People need to stop using the retail garbage out there and start using true industrial professional products.
10/15/21       #13: Lacquer sanding sealer ...
Glen
No choice but retail garbage out west. TTC doesn't sell out west anywhere. The Behlen product works great and no homeowners use the stuff as it is hard to find now.
10/15/21       #14: Lacquer sanding sealer ...
Chemmy  Member
Uhhh... Behlens started out and continued to be the number one go to "industrial" wood finishing supplier in the forties through the sixties and beyond. John Nye, their head chemist through that time, and I, were close associates, he was an excellent chemist.!!
they remained a great company until they were bought out.!! After RPM/MOHAWK bought them out, thier chemist (mowhawks) started changing their products and discontinuing
A large portion of all but their decades long best sellers, such as oz polish, blue label paste wax, Qualivite gloss lacuer, Qualivite sanding sealer, and a few others, most,were discontinued over time.
What you have now is just a name and a well deserved reputation, used to now enrich RPM.....
BETWEEN BEHLENS, STAR CHEMICAL,
AND MOWHAWK's Chemist, Mowhawk built their own brands. And added new chemistry from new chemist they hired also.!!
But please don't put down one of the most respected industrial finish companies we ever had, based on whatever Mowhawk has turned them into.
10/21/21       #15: Lacquer sanding sealer ...
bobklein
I certainly agree with the comments on mohawk’s monopoly and degradation of many of the good products that they absorbed.
I have found ML Campbell to be my go to for the last 30 years. They to keep changing their products. I don’t know if it’s greed but I do know there’s a heck of a lot of government intervention, imagine that.
I’ll agree with the one poster it’s a little difficult to surf their website. Get on the phone talk to one of the text, not a receptionist, one of their tax.
Bob Klein
Roberts antiques restorations
    • Supergrit Abrasives
