Removing oil from raw wood
1/10/21
Thomas
We had some oil accidentally get splattered onto an unfinished exterior eucalyptus door. We tried cleaning the oil with sawdust, brown paper, thinner, wax wash and have experienced limited results. Anyone have any ideas short of rebuilding the whole door? Thanks
1/10/21       #2: Removing oil from raw wood ...
rich c
What kind of thinner?
1/10/21       #3: Removing oil from raw wood ...
rich c
What kind of oil, what kind of thinner?
1/11/21       #4: Removing oil from raw wood ...
Thomas
The oil is non detrgent 30 weight. We use it to oil the bearings on our jointer. If too much is put on it slings a little bit out. The thinner is mohawk brand lacquer thinner, mineral spirits from lowes, wax wash remover.
1/11/21       #5: Removing oil from raw wood ...
DannyB Member
Eucalyptus can be oily already, so this may be hard.
If you really want to remove this rather than redo, you’ll have to use some form of poultice and let it sit.
1/11/21       #6: Removing oil from raw wood ...
Thomas
The poultice idea is the direction I was thinking. I will pick up some whiting and and mix it with the mineral spirits and give it a go.
1/11/21       #7: Removing oil from raw wood ...
rich c
How about just covering it with wood flour out of a sander for a couple days? No more liquids!
1/18/21       #8: Removing oil from raw wood ...
I used a piece of Mahogany for a top rail that had some oil in it. I noticed it, but it was seeping out a bit, I figured it would plane off.
It did not. Tried wood flour, oil dry, wood cleaner, various solvents. None worked. Finally routed the rail surface down about 3/16" and made a new part same to fit. Glued it in, and never thought about it again.
Time to make some new babbitt bearings for that jointer, eh?
1/18/21       #9: Removing oil from raw wood ...
Thomas
David, I am working a little at a time cleaning the oil. It has taken some time but it seems to be getting better. As far as the babbitt bearings go...I believe it is just the old oil seals. 1927 Crescent 24 inch jointer. Would not trade it for anything.
10/2/21       #10: Removing oil from raw wood ...
sam pettit  Member
Website: sheldonpettit@yahoo.com
Thomas, if this happens again in the future, use a 5-10% solution of phosphoric acid. Apply the solution with a spray bottle, let it set for a couple of minutes (keeping it wet)
And then wipe with wood alcohol
( Methanol) let dry and repeat if necessary.!
"Always" test on a sample piece, before using it on a project piece ok?
Good luck.!!
    • Supergrit Abrasives
