Optimizing your materials
4/25/22
I was wondering what you are doing to optimize your material use with the finishes that have a short pot life. Also has anyone come up with a good container for your pick up tube to sit in on your air assist and your airless sprayers?
I find when you are doing smaller jobs, it is difficult to optimize the use of coatings, I like to use my Kremlin air assist pump. you mix up a litre or quart of material and you have to try get most of it in the pump and then the pot life is short so you need to try use as much as you can before it goes bad.
Thanks for any help.
4/25/22       #2: Optimizing your materials ...
chris
you can buy a hopper assembly for your AAA system so you can spray smaller quantities.
4/25/22       #3: Optimizing your materials ...
Mastercabman
Like Chris said,
You can get a hopper to use on your pump
I got one when I got my CAT pump
Used it a couple of times and never bother with it again
I know what you mean by mixing enough but not too much
I use mixing cup/container and put it inside a 5 gallons bucket
A place a small object at the bottom of the bucket to keep my mixing cup tilted
My pickup tube will suck up just about everything, except maybe an oz or 2
In reality,if I just have a little to spray,I set up a gravity feed gun with a 3M pps cup
Don't have much to clean
With a hopper,I found that I use as much lacquer thinner and as much time to clean than using the pickup tube
4/25/22       #4: Optimizing your materials ...
Mastercabman and Chris,
Thanks for the info, I talked to my dealer this morning and he said basically what you said Mastercabman. The hopper attachment is quite expensive, it takes almost the same amount of material to fill the pump and hoses and he said it is more of a pain to clean.
So I am also thinking of putting a smaller container in a pail, I was thinking of looking for a tall and slender glass flower vase?
I have a couple sata gravity guns but I started spraying some Renner and Envirolak water based products and I was having troubles getting much fluid out of the gun. I was using a 1.8 tip like recommended by the supplier.
4/25/22       #5: Optimizing your materials ...
Mastercabman
No problems!
That's funny that you mentioned a vase type of container
I wish someone would start making a linear that would fit a 2.5 qt pail that gets narrow at the bottom like a funnel that the pickup tube seats nice and steady
Mmmmmmm, maybe I should patent that idea!?!
4/25/22       #6: Optimizing your materials ...
4/25/22       #7: Optimizing your materials ...
Put the pickup tube upside down and figure out a setup that will produce a seal. That way you get to use everything if you put your cup above the level of the pump.
4/26/22       #8: Optimizing your materials ...
Tom Gafgen
Maybe turn the tube upside down like Leo said and stick a funnel in it .
5/3/22       #9: Optimizing your materials ...
chris
i would try to figure out your problems with your Sata guns.
most efficient for small quantities.
i have a kremlin AAA system but for small quantities I use the new 3M gravity feed gun. very easy to change cap size and to clean.
5/3/22       #10: Optimizing your materials ...
Jim b Member
Upside down and funnel would be the hopper.I have hoppers on both kremlin and cat pumps no problems
5/6/22       #11: Optimizing your materials ...
Mastercabman
Just a thought
If you happen to have any of those gravity feed gun cup
You could try to make an adapter to put on your pick up tube and attach it to the cup
Just need some zip tie to secure it and voila!
