Bleaching walnut
4/24/24
rich Member
Website: http://www.handmadefurniturecompany.com
I've got a project where the client's designer is asking us to bleach walnut. Its a large and thick solid wood table. I've bleach things a few times but nothing on this scale. I'm wondering how much control of the color I have with the bleaching. Does anyone have any experience doing this and if so can you provide any suggestions. Thanks
4/24/24       #2: Bleaching walnut ...
Pete
I have bleached walnut on quite a few jobs. Ive used the two part bleach. As far as control, you wont have a whole lot, if any. It just knocks the color way back so you can get the old faded antique look. I have noticed that the steamed walnut will tend to go lighter after the bleach where the non steamed walnut will remain a little darker. If it is a new table you are working on, save your cut offs for samples. If it is an existing table that you are stripping then Im not sure how well the bleach will work as Ive never done that. Either way, whenever I have to use bleach, I always explain how there isnt a whole lot of control you have with it. Always make sure you neutralize the bleach.
4/24/24       #3: Bleaching walnut ...
rich Member
thanks...its all new material...the lack of control is the concern I have. Appreciate the info.
4/24/24       #4: Bleaching walnut ...
Pete
The lack of control will only matter depending on how light they want to get the wood. A new, fresh batch of bleach will knock the color back pretty far. Older bleach doesnt work as well.
4/24/24       #5: Bleaching walnut ...
rich Member
thanks and do you have a favorite brand of bleach
4/24/24       #6: Bleaching walnut ...
Pete
I use a 2 part wood bleach. There is no name on the box. I get from a really good local paint store.
4/24/24       #7: Bleaching walnut ...
rich Member
thnx
4/24/24       #8: Bleaching walnut ...
duster
I made this walnut table and used a 2 part bleach on it. It was pretty easy to do, but as Pete states, you don't have a whole lot of control on how intense the bleaching ends up. Perhaps you could dilute it a bit if you were looking for a reduced bleaching effect. I would definetly do some samples on scrap. We did some samples, and noticed that the bleach was raising the grain.
Since were were looking for a smooth finish, we sponged water onto the top, let it dry overnight and the sanded it smooth again before bleaching. This seemed to help a lot.
The client loved the final result, but to me it was a desecration of $1200 worth of walnut.
View higher quality, full size image (800 X 844)
4/24/24       #9: Bleaching walnut ...
rich Member
thanks Duster
5/12/24       #10: Bleaching walnut ...
Aaron
I've done quite a lot of bleaching of walnut, and it's true you don't have a lot of control over the color (this depends of course on the composition of the wood you're starting with – hardwood v. softwood, figure and grain, etc.). One measure of control you do have is how many times you bleach the wood. In my experience 3-4 times with A/B bleach is necessary to achieve a fairly even tone, and this is also the point at which the bleaching 'maxes out.' Once the wood is completely bleached you can stain/tone to even the color further. One important step: after bleaching you should use white vinegar to stop the chemical process – this is especially important if you're only bleaching once to just lighten the wood a little.
Finally, I always sand with 320 after the bleaching process is completed. This is enough to smooth the grain back and not sand away the top layer to expose unbleached wood underneath.
6/17/24       #11: Bleaching walnut ...
Chemmy
Probably way to late to be of help, but if your having troubles, contact me, I will be pleased to help..!!
6/17/24       #12: Bleaching walnut ...
rich Member
Thanks all. Not sure where this will end up shaking out but thanks all for the suggestions and guidance.
