Furniture Making
Subject: Re: Furniture designer
Furniture designer
11/18/25
Brandon Member
Is there anyone here who is able to design furniture for me from my concepts?
I am looking for someone that can help me with 3d, templates, designing my work into how many pieces I would need, and for best production process.
So an example would be, this chair leg that go up to the top of the chair back, would need to be done with 2-4 pieces, glued at these areas. Should have support here. Ect.
11/24/25       #2: Furniture designer ...
Thomas M Diel  Member
Website: http://thomasdiel.com
Hi Brandon,
Don't take this the wrong way but your ask is too broad for a detailed reply.
What info would you provide ie; scaled hand drawings, CAD drawings, sketches or what I refer to ask talkatecture, no offense again but there are many here that could provide the gambit if we knew more about what you need and what your budget would be? Basic shop drawings for designer approval being 3D model ie an isometric w 3 views as a basic could be $500.00/per & up range, but that is shape and form to convey scale and look. Then full blown modeling with parts breakout drawings & joint construction details being dowels vs tenons would be in the $2-5K. Then there is the question of scale manufacturing are your designs to be CNC routed from plywood or back legs like you refer to being a total of 10-15 in quantity = stick built low volume bandsaw & template route /sand, or in the hundreds which your more than likely doing one-peice flow CNC jigs or templates for profilers which would be high volume production runs that more than likely need prototyping. Do you have a manufacturer identified or are you job shop sourcing?
Then you say concepts, so how many designs are you looking to have fabricated and number of each and most importantly what is your timeline? I have reverse engineered other designers 3D models for production but that was in-house for a contract furniture manufacturer where I designed to the constraints their equipment and processes. Is there upholstery, foam, cut n sew, metal ....? Who is your audience, low budget or contract grade ie corporate / hospitality high end which use more expensive materials and processes.
I am booked 6months currently, best of luck,
Tom
12/11/25       #3: Furniture designer ...
Dave Sochar
I think you are splitting a single -task- into two tasks. The reason it is a single task is that it is just a single task.
I once met a man that called himself an upholsterer. He had spent 12 years doing the outside left arms for every piece in the line. He was lost on the other arm, the back, the deck, etc.
Over specialisation is to be avoided. If you cannot do the whole task, you need to hire someone that can. The best designs have come out of a single head. You might read some of what Charles and Ray Eames have to say about the subject. Or Frank L Wright.
2/20/26       #4: Furniture designer ...
David William  Member
Yes, this is absolutely possible. I’ve worked with designers and technical drafters who specialize in turning rough furniture concepts into production-ready plans. What you’re describing, 3D modeling, breaking designs into individual components, determining joinery points, structural supports, and the most efficient production process, is exactly what a skilled furniture CAD designer or industrial designer can help with.
For example, with a chair leg that extends into the backrest, they can model it in 3D, test proportions, and decide whether it should be built in 2–4 laminated pieces for strength and stability. They can also specify glue joints, reinforcement areas, load-bearing calculations, and material thickness based on your intended use.
I’d recommend looking for someone experienced in furniture prototyping and woodworking production, not just general 3D design. That expertise makes a huge difference in real-world build quality.
