Furniture Making
Subject: Re: Bevel Slat Door Tips
12/17/25
Isaac  Member
Website: http://www.milkbuilt.com
I'm about to start a build on a record cabinet that will have bevel slat doors and am looking for some advice/knowledge from anyone who has had experience making something similar. The doors will be solid flatsawn white oak with the slats running perpendicular to the grain. I'll be cutting the slats (1/4" deep 60 degree v-groove ) on the CNC. The doors are slab style so I won't be able to rely on a frame to help maintain flatness and account for seasonal movement. The largest door will be 16" x 18".
I'm a bit concerned about the doors warping and would like to avoid placing battens on the door interior. I have had issues with removing material from only one side of a solid wood panel in the past. Any tips? I'm not opposed to creating engineered panels (CLT, stave core or similar) but feel that 5/16" thick "veneers" are a disaster waiting to happen.
View higher quality, full size image (1162 X 971)
View higher quality, full size image (1813 X 1012)
12/17/25       #2: Bevel Slat Door Tips ...
Jr Lee  Member
Website: http://www.leecabinets.com
Isaac I have only done a similar door using MDF on my CNC but I too would be concerned about cupping/warping for the size you mentioned. I would also be concerned about the V bit splintering the material as it exits the crossgrain cut. That could easily be remedied by oversizing the doors before machining and trimming to size afterwards. Good luck
Jr
12/18/25       #3: Bevel Slat Door Tips ...
Isaac  Member
Thanks Jr. A colleague mentioned some concealed door straightening hardware from Hafele and Sugutsune that I'm looking into. They're meant for larger doors but I believe I could cut them down. Also thanks for the heads up on the splintering - I'll oversize them or use a backer to avoid this.
12/18/25       #4: Bevel Slat Door Tips ...
Give some thought to the hinges you select. You will have a very shallow depth of material in the hinge area if you use typical euro cup hinges. Also do an expansion and shrinkage calculation to estimate how much the door height will change seasonally.
I don't envy the finish sanding you will have to soften all those edges.
1/5/26       #5: Bevel Slat Door Tips ...
Dave Sochar Member
Bevel Slat is not a meaningful phrase or description. What you are emulating is simple v-joint resulting from a tongue and groove run on reach edge of a board. The v-joint area is a 'crush' zone for expanded solid wood. The joint never looks good if it is in laminated board or plywood.
Assuming solid wood, how do you plan to accommodate wood movement?
1/15/26       #6: Bevel Slat Door Tips ...
Alex_Zhang Member
Website: https://yhcncrouter.com/
Your concern about warping caused by single-sided material removal is entirely valid. For solid wood door panels, the key is managing the internal stress balance of the wood. An often overlooked but effective method is to perform "compensatory" machining on the back side.
My specific suggestion is: After completing the V-grooves on the front using a CNC machine, mill a shallow (e.g., 0.5-1mm deep), wider relief groove on the back of the door panel, corresponding to the centerline of each V-groove, using a small straight or ball-end cutter. This serves two main purposes:
Stress balancing: Removing a small amount of material from the back helps balance the asymmetrical stress caused by the front grooving, significantly reducing the overall tendency to warp.
Providing expansion space: The shallow groove on the back provides a small "give" space for the wood to expand perpendicular to the grain, mitigating the pressure on the panel's flatness caused by expansion.
Combining this with the suggestions from other members, a complete solution sequence could be:
Material preparation: Choose thoroughly dried and stress-relieved wood. After purchasing the boards, allow them to acclimate in the workshop environment for at least a week.
Sizing strategy: Adopt Jr Lee's suggestion of processing large rough blanks and then performing final shaping.
Machining sequence: First, machine the shallow relief grooves on the back, then perform the final V-groove machining on the front.
Hardware and calculations: Carefully consider the hinge depth issue mentioned by Tom and the expansion calculations emphasized by Dave.
While this adds a few processing steps, it fundamentally improves the long-term stability of the product from a physical perspective, avoiding complete reliance on later corrective hardware.
1/16/26       #7: Bevel Slat Door Tips ...
Pete
I may be late to respond to this but I was wondering if you could approach the project with the V groove pieces as a "skin". So if your groove is 1/4" deep, mill it out of stock that is 5/16 to 3/8 thick. Id consider v grooving the back if possible to relieve stress and then glue that entire piece onto a case? Not sure if that would even work and it may need some more thought...
1/16/26       #8: Bevel Slat Door Tips ...
Isaac  Member
Thanks all. I'll take this all into consideration! The majority of each door panel will be rift/quartersawn and I'm giving myself 3/32" reveals with the max width across grain being 17.8125. Not too worried about expansion issues, just the warping. I'm going to spend the extra hour or two balancing the v-grooves on the opposing side. I'm cnc'ing it so no need to be lazy haha.
1/20/26       #9: Bevel Slat Door Tips ...
David William  Member
For slab doors of that size, solid flatsawn oak will definitely move with the seasons, especially if you’re doing deep V-grooves on one side. To minimize warping, consider a balanced approach: you could make a thin stave or laminated core with solid oak faces, so the grooves aren’t cutting all the way through a single board. Another option is to CNC both sides to balance stress, though that doubles the work. Proper acclimation of the wood before cutting is also key.
1/22/26       #10: Bevel Slat Door Tips ...
Dave Sochar Member
Make your v-joint full thickness, and make it so it looks as if it is solid wood. Because it is. I would up the thickness to 1-1/8" or so. Across the board, as they say.
Plow into each end of each board about 3/8" to 1/2" x 1-3/4" deep.
This plow will then snugly receive what we call a stile if turned 90 degrees. Glued in place, it will stop the movement of the v-joint and hold outside dimensions stable so you can get proper clearances. Just do not try to clamp the width up tight - leave a bit of room (0.0150") so each board can move within its own orbit - just like hardwood floors.
4/24/26       #11: Bevel Slat Door Tips ...
You’re right to be cautious, cutting V-grooves on one face will absolutely introduce imbalance. I’d avoid solid flatsawn for this and go with a balanced panel: either rift/quartersawn stock or a shop-made ply/stave core with similar thickness lamination on both faces. Even a shallow relief pass on the back can help equalize tension. Keep moisture content stable and finish both sides equally. At that size, a well-built engineered panel will outperform solid every time.
