Sawing and Drying
Subject:
Gang Saw advice
4/27/25
Bill Sawyer Member
Website: http://www.sawyerplastics.com
I need some advice. I manufacture large uhmw polyethylene parts for papermachines. No wood, but we use woodworking machinery. I need to increase productivity by making mutliple cuts on our large "board stock" The maximum size is 2 1/2 thick by 20 by 400 inches. This would work out to about 400 lbs. The feed rate needs to be high as the material will melt at slow chip load.
I have never used a gang saw before and I need to know if standard equipment would be able to handle this load, I would also appreciate any guidence on manufacturersas well if possible.
Please respond by my email and thanks very much.
Bill Sawyer
4/28/25       #2: Gang Saw advice ...
Dustin Orth
What saw are you using now to cut those blocks? How wide are the cut parts? How many of these cuts are you making a day? You mentioned 20x400, is that your raw stock or finished cut size? A gang rip might do a good job but its going to be blade choice and feed rate that are going to be your main thing. A good roller style power fence would be another thing to look at. Hp of gang rip saws will be sufficient to make a lot of cuts in one pass but if you are cutting 20" wide with a blade every 1" and 2 1/2" thick, that would require an insane amount of power, maybe more than the biggest saws have at 100hp. That may take a call to mareen johnson. If you are only cutting 2 or 3 blades, 50-75hp would be plenty. Good thing is plastic is a consistent material so once you get everything dialed in, your good to go except for changing dull blades out.
4/28/25       #3: Gang Saw advice ...
Bill Sawyer
Website: http://www.Sawyerplastics.com
Thanks Dustin:
We are currently using a saw we made 30 years ago. I DeWalt industrial radial arm saw on a track. We make one cut at a time at about 30 inches per minute. Our saw blade is a 14-inch special thin curf of 1/8in. We sometimes need to make cuts as narrow as 1in. from a board of about 14 in. wide at up to 2 in thick.
My biggest concern is the ability of a machine to pull something this heavy through the sawblades.
Our business in growing and our current methods are holding us back
Thanks for your response. I am grateful
4/28/25       #4: Gang Saw advice ...
Dustin Orth
I'm attaching a video link of my gang rip saw. https://youtu.be/Jp1Xnj03AtQ This an older video but I still have the same saw.
4/29/25       #5: Gang Saw advice ...
I suggest you call Mareen Johnson, manufacturer of Gang Rip saws in US. Their tech people can tell you, and they might even send you to one of their saws near you.
5/23/25       #6: Gang Saw advice ...
David William  Member
Hi Bill, a gang saw could be a viable option, but standard models might struggle with your material size and weight. Look for heavy-duty gang saws designed for plastics or composite materials. Companies like Cantek or Raimann may offer suitable solutions. I recommend contacting manufacturers directly for custom specs. Good luck with optimizing your productivity.
3/30/26       #7: Gang Saw advice ...
Daniel Member
Calling Mareen Johnson directly is genuinely the right move here — gang rip saws for non-wood materials is a pretty specific application and you need someone who can actually spec the HP and blade configuration for UHMW at that thickness and weight. The feed rate concern is real, that stuff will gum up fast if chip load is off, and a standard woodworking setup won't account for that without some customization upfront.
4/23/26       #8: Gang Saw advice ...
Casting Crown Member
A gang saw could definitely improve productivity for large UHMW parts, but because the material can melt quickly, maintaining a high feed rate and proper chip load is essential. It may be worth checking with experienced industrial machinery manufacturers to ensure the equipment matches your load requirements safely.
