Sawing and Drying
Solvent/Chemical Drying
9/28/20
OliveWoodGuy Member
While reading up on drying methods, I came across solvent drying (or solvent seasoning) as a method for drying out green wood—problem is, I can't find much more about it. There was a study published on it back in 1965 along with a methodology, but the trail goes cold after that. I even found the patent for it, but the only other patents citing it are completely unrelated.
Does anyone know why this fell out of favor? I'm assuming factors related to costs, but I don't know if it was just a bad idea that led to structural issues.
Study on solvent drying
9/30/20       #3: Solvent/Chemical Drying ...
rich c
I know woodturners that submerge rough turned work in barrels of denatured alcohol. Pretty soon the alcohol starts moving towards a higher water content and has to be refreshed. In a commercial setting, this would require a steady supply of solvent and get expensive, fast!
10/1/20       #4: Solvent/Chemical Drying ...
Gene Wengert
There is also the solvent in the wood that is evaporated, and it would be necessary to capture this solvent for reuse as the solvent is expensive, and avoid releasing it into the air where it would be a pollutant.
Although alcohol is a non-swelling liquid, so there is no shrinking of the wood during drying, after drying, moisture in the air does cause excess movement of the wood when the humidity changes naturally.
10/1/20       #5: Solvent/Chemical Drying ...
Keith Newton
I would think there would be a pretty high fire hazard risk compared to other drying methods.
10/2/20       #6: Solvent/Chemical Drying ...
OliveWoodGuy Member
There aren't any commercial kilns using this method then? I looked around on YouTube out of curiosity, and only managed to find videos of Indians talking about this method weirdly enough (didn't think there'd be a huge kiln drying industry there).
I suspected that the costs would be a major factor, though solid facts have been hard to come by. I'm still wondering if there's risks of structural damage occurring (depending on the solvent used).
10/8/20       #7: Solvent/Chemical Drying ...
Louis Oberholtzer
I don't know what you intend to dry, but I assume it is a specialty product of some kind. You may want to look at vacuum drying or even PEG. We offer custom drying via several methods. No method is perfect, but some improve on others depending on the final product.
10/8/20       #8: Solvent/Chemical Drying ...
Louis Oberholtzer Member
